Question on this newly listed NSR3043 SHARK "EVO" 25 Balanced standard Mabuchi can sized motor? When I cut the label to create clearance to mount in a slot.it sideways pod i noticed that the motor can was stamped 22000. In other NSR motors that stamping correlated to the motor rpm. I did not test rpm but wondered if anyone else had noticed this or would know why motor is stamped that way. I will probably pull motor to test rpm. Just wondering...?
Aloha
Dale
