thunderslot lola
thunderslot lola
Postby docdoom » Fri Jan 05, 2018 11:00 pm
Is there a safe way to remove the car number from the car paint with out damaging the number plate? wish to change the 8 to a 9 to match the team car that ran at Daytona. or would be safer to decal a new number plate and 9 over the old one.
docdoom
Re: thunderslot lola
Postby Mitch58 » Sat Jan 06, 2018 9:38 am
Sharpie? You'll probably get a better answer from Greg.
Mitch58
Postby Rooster » Sat Jan 06, 2018 9:51 am
I would consider using a Molotow white Acrylic Marker to go over the current number. Then, I would decal over the old number. Go over the old number as many times as you need to with Molotow marker to make sure that the old number doesn't bleed through.........that's probably what I'd do. But, I'm not an expert.
Rooster
Postby GPCruisr » Sat Jan 06, 2018 10:12 am
Buy the white body kit and paint it to the livery if choice.
Thanks
Bear
"Don't poke the Bear"
GPCruisr
Postby dw5555 » Sat Jan 06, 2018 10:22 am
GPCruisr wrote:Buy the white body kit and paint it to the livery if choice.
Matt I know you like painting all your cars but that's a lot to go through to change a number..
Dave
Enjoy who you race with, not how you should be racing.
dw5555
