132 scale slot it or racer sideways ?
Fri Jan 05, 2018 2:20 pm
by rick42
I am looking at these 2 brands of cars. I will be using them on a Carerra 132/124 analog track. Would one be better than the other ? Does anyone have any recommendations on cars for this track. I am wanting to go with a light magnet car instead of the heavy magnet ones.
Re: 132 scale slot it or racer sideways ?
Fri Jan 05, 2018 2:35 pm
by MikeyAutobahn
Can't really speak for Racer Sideways as I've never owned one [although I'd like to], but I have five Slot.it cars that I run on my Carrera track and I love 'em. They're very nicely made, easy to work with, and run great with or without magnets.
I think the only reason I don't own a Racer Sideways [or something like it] is only because I found a lot of body styles that I really wanted from Slot.it.
Fri Jan 05, 2018 3:19 pm
by Z-carfan
The Racer Sideways cars use Slot.it mechanicals. Gears pinions and the like. The run Great on Carrera tacks along with the Slot It's. In my opinion.
Fri Jan 05, 2018 4:06 pm
by Pappy
The Racer Sideways Daytona Prototype is a great handling car. And like Z-carfan said, they use Slot It gears and motor pods.
Fri Jan 05, 2018 4:30 pm
by gascarnut
Fortunately, there's very little cross-over between Slot.it and Sideways as far as the types of cars they offer. That means you won't have to choose between two identical body styles made by both manufacturers!
Slot.it have a much wider range at this point, though, so you may find what you want more easily in their range. Mechanically, some of the Sideways cars use Slot.it parts, others like the Huracan GT3 have their own parts that would probably be interchangeable anyway. The tires on the Huracan are new to me, more grippy than the C3 compound used on the Gp5 cars. I don't have any of the DP cars, so can't comment about them.
Either way you can't go wrong with either or these makes. Top quality stuff!
Fri Jan 05, 2018 5:02 pm
by chappy
Agree with Mike and Dennis. Not a bad car there. Only thing i could think of is if you are using a heacier magnet it may require a stiffer chassis, but on Carrera track you should be ok.
Fri Jan 05, 2018 6:10 pm
by Jesla
Fri Jan 05, 2018 6:17 pm
by chappyman66
Agree with the above comments. We run on Carrera track and have a Sideways Grp 5 class as well as a couple Slot-it classes. The fast lap times are nearly identical with stock configuration and the addition of silicone tires.
Both manufacturers make quick, smooth cars.
Fri Jan 05, 2018 8:05 pm
by rick42
I just ordered these 2 racer sideway 132 cars. Click on each pic for a full picture. I still dont have this photo thing down yet.
Fri Jan 05, 2018 9:51 pm
by Impulse-ive
Those are great cars and fun to run. They are have short can motors which I was going to recommend. Slot.it tends to have more short cans which I find easier to drive. but the group 5 cars sideways cars have a long can that provides a little more toque. They are the same motors slot.it puts in their LMPs. if you like the way the DPs perform the slot.it Groups Cs will run great too.
Sat Jan 06, 2018 1:58 am
by rick42
Resized the photos.
Sat Jan 06, 2018 9:45 am
by rick42
So basically ,there is little difference in the two brands. Except for the names and what body style each has to offer. I ordered the two pictured above. Other than these two , what other cars of the same two brands are you impressed with on the carerra track ? I do have an after market power supply , so I can control the volts. I do like a little drifting sometimes.
Sat Jan 06, 2018 10:18 am
by dw5555
:text-threadjacked: Slightly off topic but since you are moving up to the world of no mag and more racer quality cars, I would also consider a tire truer. Not entirely necessary for home track use but makes a huge difference in handling even on my Carrera track. Tire Razor is a good one especially for the money.
Dave
Mon Jan 08, 2018 6:33 pm
by rick42
Mon Jan 08, 2018 6:37 pm
by rick42
