Home Racing World • View topic - 1/43 De Tomaso Pantera
For 1/43rd Scale Models
Postby taskak » Sun Mar 19, 2017 11:26 am
taskak
Re: 1/43 De Tomaso Pantera
Postby pfuetze » Mon Mar 20, 2017 1:11 am
Very nice work on the Pantera, Aki!
As for the flex in the chassis: you do not want flex between the gears, the part between the rear axle bushings and the motor should be as rigid as possible, otherwise the gears will not run smooth while flexing.
i like what you did to the wheels - they look great!
the photo with the chassis in the box is great!
the details are very nice, very crisp! i like the exhausts.
Postby taskak » Mon Mar 20, 2017 1:37 am
Thanks Peter, and you are right about the chassis but it's much better to say new design than slight mistake :D
But it works, there is not that much movement.
taskak
Return to 1/43rd Scale Showcase
