AV8 Build " finished"
Postby btaylor » Tue Oct 30, 2018 5:06 am
Started on another roadster yesterday. This one is a 1929 Ford body on 32 frame rails. this was a very popular swap back in the day, as it was an easy conversion, and added V8 power to a lighter weight body of the 28-29 roadsters. Last year I had bought a model car lot off Ebay, and it had several half built, or junked out bodies from the 20's and 30's. This body was from that lot. I started with a simple brass square tube chassis, and fashioned some 32 style outer rails from this brass sheet. I soldered them to the front and rear axle holders, then braced them from the main frame for strength. I am adding front leaf springs and shocks (not in this pic yet), and other details like steering arms, radius rods etc. The guide will be slotting plus, wheels are H&R, 9/31 gears and urethane tires. Not sure on the color choice as of yet, still looking for inspiration on this one. Body will come off separate from the driver and roll bar area, so I can get some serious detail in that area. This is what I have so far.
Re: AV8 Build
Postby HomeRacingWorld » Tue Oct 30, 2018 5:41 am
Impressive work on this chassis Bob. Look forward in seeing more of this one!
Re: AV8 Build
Postby TuscoTodd » Tue Oct 30, 2018 7:44 am
Bob - you are a creative machine!
Definitely digging the start of this one and looking forward to the updates!
Re: AV8 Build
Postby strangebrew » Wed Oct 31, 2018 3:42 pm
............I can't keep up with this guy :scared-eek:
strangebrew
Re: AV8 Build
Postby model murdering » Fri Nov 02, 2018 1:33 pm
I love all character that the additional and unique fabricated parts add Bob. Seeing scratch building through your eyes has me jonesing for a scale change.
model murdering
Re: AV8 Build
Postby btaylor » Fri Nov 02, 2018 2:08 pm
Thanks MM, i know the older my eyes get, the better i like the larger cars. Its very easy to get hooked on the big un's.
Re: AV8 Build " finished"
Postby btaylor » Sat Nov 03, 2018 6:29 am
Never got a chance to throw up some finished pics!
