Home Racing World • View topic - Lotus 56B Turbine
Lotus 56B Turbine
For 1/32nd Scale Models
Lotus 56B Turbine
Postby VTECFOUR » Sat Jan 28, 2017 3:21 pm
Got this Lotus 56B Turbine body from Retro Racer's slot car estate. The side pods remind me of the current Mercedes F1 cars almost 50 years later.
I think it's a Munter cast.
Gave it my adjust-o-wheelbase chassis treatment with the Devised Designs super slimline motor pod. A piano wire chassis would probably run better but I'm just at the infant stage on that build technique.
Ran at yesterday's Friday race on a speedway type track and it went just fine. A fellow GVSCC member suggested a phantom Camel livery so I'm going in that direction with a yellow and blue finish.
VTECFOUR
Re: Lotus 56B Turbine
Postby dge467 » Sat Jan 28, 2017 8:04 pm
This will be a cool build! I am sure you will make Keith proud!
Postby VTECFOUR » Sat Mar 11, 2017 3:16 pm
Progress. Sprayed on some Tamiya Camel Yellow. Painted turbine intake and cast Mclaren wheel inserts in contrasting blue. Applied appropriate phantom livery decals.
Need to find a reclining driver figure, make or find a windscreen and paint detail the suspension.
Looks good so far and runs well so everything work out. Retro Racer 44 would approve.
VTECFOUR
Postby Changing-Gearz » Sat Mar 11, 2017 5:00 pm
Changing-Gearz
Postby WB2 » Sat Mar 11, 2017 6:15 pm
Any idea who made the body?
WB2
Postby VTECFOUR » Sat Mar 11, 2017 6:39 pm
Thanks for the Immense Miniatures driver figure tip.
I'm guessing that Keith got the body from Munter in New Zealand.
He entered the two earlier Lotus Turbines in the 100 Years of Indy Proxy so I was surprised this version was available in his slot car estate.
VTECFOUR
Postby munter » Sun Mar 12, 2017 12:22 am
Return to 1/32 Showcase
