Revell Monogram BMW 320i - brass chassied
For 1/32nd Scale Models
Postby VTECFOUR » Thu Sep 01, 2016 5:52 pm
Been having fun re-chassising existing cars. My modified Revell Monogram BMW 320i purchased from Pendle Slot years ago never ran well, so let's see if a brass chassis will help.
The modelling takes much longer than building a chassis for me so this is nice relief.
VTECFOUR
Re: Revell Monogram BMW 320i - brass chassied
Postby Retro Racer 44 » Thu Sep 01, 2016 10:46 pm
I hear you Dan, that was my take on it as well. I will always use an existing painted and detailed body if I can.
There is now no doubt, you will have a fast brass chassis car for every class we race at the GVSCC. There goes my constructor's championship, eh?
Keith
Retro Racer 44
Postby DixonJohn » Fri Sep 02, 2016 12:31 pm
I need to do something like this to mine. Really like the car, it just has never run well either
DixonJohn
"The Mayor"
Postby Wobble » Fri Sep 02, 2016 6:26 pm
That'll make it go. I can't do brass so I jammed a Sideways Capri chassis under mine a couple of years ago and it goes good. I've just been given another one but now i can use a Sideways Beemer chassis instead if they have the same wheelbase.
Wobble
Postby VTECFOUR » Fri Sep 02, 2016 9:22 pm
Chassis's running.
Parts list includes:
Motor pod - Professor Motor
Main rails - 1/8" square brass tubing, 3/32" piano wire
Guide tongue and side pans - .063 brass sheet
Guide\braid\wire - Sloting Plus, Slot It, Slot It
Motor - Scale Auto 26K S can
Pinion/Crown - SCX Pro 9t, Slot It 27t
Front rims/tires - Slot It 15 x 8, Slot It low profile
Rear rims/tires - Slot It 17 x 8, Paul Gage
Mounted body with single posts front and rear using 4-40 brass screw inserts in Evergreen 7/32" styrene tubing.
Could possibly be lowered at the front but always wary of tire rub.
Runs well with a planted feel and good spunk even at a hefty 114 grams.
VTECFOUR
Postby valie » Sat Sep 03, 2016 8:26 am
Nice one, I like it!
valie
Return to 1/32 Showcase
