Home Racing World • View topic - Lola T290 build
Lola T290 build
For 1/32nd Scale Models
Lola T290 build
Postby VTECFOUR » Thu Jul 14, 2016 7:32 pm
Had this Lagartijakit Lola T290 resin kit for awhile so it's time to put it together.
Uses the Sloter Lola T280 body components and chassis. I'm going to pass on the latter and put my own plastic/brass chassis underneath.
VTECFOUR
Re: Lola T290 build
Postby Retro Racer 44 » Thu Jul 14, 2016 7:40 pm
Should be another winner, Dan.
Cheers,
Keith
Retro Racer 44
Re: Lola T290 build
Postby HomeRacingWorld » Thu Jul 14, 2016 9:50 pm
Yes sir, this is a nice car. Will follow.
Re: Lola T290 build
Postby Retro Racer 44 » Thu Jul 14, 2016 11:07 pm
I just googled this car, and most pics do not show the tall vertical fins. Since they are a potential breaking point anyway, you might want to customize it to one of the other styles. There are even pics of the 27 Kodak car without the tall fins.
Cheers,
Keith
Retro Racer 44
Re: Lola T290 build
Postby Abarth Mike » Thu Jul 14, 2016 11:32 pm
Abarth Mike
Re: Lola T290 build
Postby VTECFOUR » Fri Jul 15, 2016 12:32 pm
Hi Keith,
Yeah, those tail fins are pretty thin and vulnerable to breaking. However, that modelling feature was what attracted me to the body. It's also got a nice ridge along the top of the body sides like a McLaren 8D. If they eventually get broken, I'll just trim them off.
Got the basic chassis pan done to fit the Devised Designs super slimline motor pod, so it'll be rolling soon.
VTECFOUR
Re: Lola T290 build
Postby VTECFOUR » Fri Jul 15, 2016 11:02 pm
Chassis's mostly done...
...so the body can be mounted.
Side pans are next and then a test run on my twisty wood track.
VTECFOUR
Re: Lola T290 build
Postby HomeRacingWorld » Sat Jul 16, 2016 1:37 pm
Yes sir, really nice.
Re: Lola T290 build
Postby VTECFOUR » Wed Jul 20, 2016 2:09 pm
Some progress.
- Straightened out warped body sides with a clamp and heat gun.
- Epoxy filled head lamp cavities.
- Seated Slot It Sauber wheel inserts (rears modified) into the 15 x 8 fronts and F1 rear rims.
- Cut rear wing and interior tray from styrene sheet.
- Modified a Fly Classic driver figure.
Mock fitted the interior tray, driver figure and wing.
Going to work out.
VTECFOUR
Re: Lola T290 build
Postby VTECFOUR » Sat Jul 23, 2016 2:16 pm
Done!
Sprayed on some Tamiya white primer then Camel Yellow, one of my favorite colors. Applied the fiddly decals and paint detailed to finish.
Runs well, but not as fast as my Porsche 908-3 conversion. A good companion anyways.
I'm primed now to take on my 1/24 Lancia Stratos build's Alitalia decal sheet.
VTECFOUR
Re: Lola T290 build
Postby valie » Sat Jul 23, 2016 2:34 pm
Wow! Great build!
valie
Re: Lola T290 build
Postby Retro Racer 44 » Sat Jul 23, 2016 3:32 pm
Swwweeeeet!
Retro Racer 44
Re: Lola T290 build
Postby chappy » Sat Jul 23, 2016 8:00 pm
Nice Job Dan, really finished up well
Re: Lola T290 build
Postby Lou E » Sun Jul 24, 2016 5:47 pm
That turned out awesome! Very nice work on a really cool car.
Lou E
Return to 1/32 Showcase
