Home Racing World • View topic - Policar/Slot.it “Simple Chassis” GT4
Postby HomeRacingWorld » Thu Feb 01, 2018 10:21 pm
From the MRE Toy Fair Report.
Policar set cars won't come from the normal range by Policar or Slot.It. There is a need for simpler cars and these are already decided. The sample Toyota rally car that was available to test is great fun to drive - without magnets you can slide it to silly angles and it just recovers without deslotting, exactly what you need for a set car.
The technical parts are very simple - press-fit wheels and crownwheel, S-Can motor rated at 18K, tyres that work well on the new track but also have a decent lifespan, and a bodyshell without too many bits than can fall off. Maurizio confirmed that the second set car will be a version of a Slot.It car - see another post for more information about this. One thing we did like very much - the set car guide has a replaceable blade which is changed by simply sliding it out from the front and replacing it with a shallower one that will be supplied, allowing the cars to run on other tracks. The Policar track has a slot 8mm deep.
So it looks like a new car/chassis is on the way.
Re: Policar/Slot.it “Simple Chassis” GT4
Postby WB2 » Thu Feb 01, 2018 10:29 pm
Doesn’t that look rather Carrera-ish?
WB2
Postby valie » Fri Feb 02, 2018 4:40 am
valie
Postby TuscoTodd » Fri Feb 02, 2018 9:45 am
Interesting!
I like the comments about stability and drifting - that ought to make for a fun car to run! :)
Postby Wobble » Fri Feb 02, 2018 2:21 pm
I saw a video clip somewhere of this running and it has a surprising amount of zip for an 18k motor. With simple tuning it should be easy to get even more out of it.
Wobble
Return to Slot Car News!
Users browsing this forum: No registered users and 35 guests
