Home Racing World • View topic - New Slot.it Wheel Codes/Descriptions
Postby HomeRacingWorld » Mon Nov 28, 2016 12:16 pm
From Slot.it
In order to make it easier for our end user customers, following many requests, we have decided to replace old codes with better ones for our popular wheels.
The old product code, to make transition easier, will still be printed on the product packaging.
Here is how it works:
We have taken the three important dimensions (diameter, width, hub thickness), and used them to create the code.
For example, our wheel WH1110-Al is 17.3mm diameter, 8.2mm width, 1.5mm hub: it becomes W17308215A
W for wheel diameter in mm 17.3 --> 173 width in mm 8.2mm --082 hub thickness in mm 1.5mm -- 15
A for aluminium
Another example:
old code PA17-Pl (15.8*8.2*2.5mm)
new code W15808225P
W = wheel
158 = diameter
082 = width
25 = hub width
P = plastic
Thus, starting from today the codes for the following will be replaced as explained above.
We believe that this change will make things easier for everyone - even if we understand that there will be some initial perplexity.
To minimize this, the stickers on the bags will carry BOTH old and new codes.
Effective January 2017 all Slot.it wheels will be coded according to this rule.
Old part Replacement part
(came w/insert) (insert removed)
PA17-Pl ----------------> W15808225P
PA24-Als -------------> W15808215A
PA43-Als --------------> W16508215A
PA43-Pl ----------------> W16508225P
PA33-Als --------------> W14308015A
PA20-Als --------------> W14411515A
Re: New Slot.it Wheel Codes/Descriptions
Postby gascarnut » Mon Nov 28, 2016 1:23 pm
Thanks for the info, but oh dear what confusion this will cause!
For example, how will the new numbering distinguish between the PA19-Als, the PA19-Alf and the PA19-Alh? There's no logic in the new numbering system to identify whether the wheel has double shoulders instead of a solid center,and whether the double shoulder wheels have the drilled channel or not.
Or are they only going to change the few wheel numbers that were listed?
Hopefully we will get more info from Maurizio in due course.
gascarnut
Postby HomeRacingWorld » Mon Nov 28, 2016 2:31 pm
Funny. Because many have done nothing but complain about the "old way" and wanted a new, more accurate system. Almost identical to how PG lists his tires :)
I am sure they will come up with a good plan :)
Postby WB2 » Mon Nov 28, 2016 3:09 pm
That description made my brain hurt.
The sizing is great if one has a bare wheel in hand. If the wheel is on the car, I'd rather use the diameter of the rim that I can see. That would be D-2x rib thickness.
WB2
Postby DaveKennedy » Mon Nov 28, 2016 3:19 pm
Well it's a logical reason and I understand what they're getting at but it's such a long series of numbers... I just don't know about this idea of replacing the whole product description with this.
Postby SuperSlab » Mon Nov 28, 2016 9:07 pm
This works for me: I like more information and this is logical. I have on more than one occasion been unsure if I was ordering the correct wheel: this removes any uncertainlty.
Alwyn
SuperSlab
Postby Abarth Mike » Mon Nov 28, 2016 9:16 pm
Great but scratch builders need the visible diameter and the ridge width. OK Slot.it uses Euro "std" 5mm ridge but... F1 are 7-7.5mm!
I am sure we will muddle through. Best advice? Everyone buy some digital calipers. Then even the PG method will make sense.
Abarth Mike
Postby Billy boy » Tue Nov 29, 2016 5:18 am
I'll stick with CB design wheels,no need to over complicate things.
Billy boy
Postby cgingras » Tue Nov 29, 2016 1:41 pm
cgingras
Postby gascarnut » Tue Nov 29, 2016 3:20 pm
Thanks Christian - I missed that on the drawing, I see it now.
Personally, I have never been a fan of intelligent numbering systems, it is way too easy to paint yourself into a corner, as Slot.it have shown with now three different schemes for wheels, and at least two for tires so far. No intelligence in the number does require more standardization of the description of the item of course, but that's usually easier to adapt to changing circumstances.
/rant...
gascarnut
Postby Abarth Mike » Tue Nov 29, 2016 9:23 pm
Abarth Mike
Postby HomeRacingWorld » Tue Nov 29, 2016 9:33 pm
Perhaps it's why SCC, PG, and most other makers make very easy to follow tire selection tools. :whistle: Maybe not for every slot car ever made, but certainly for our modern aluminum choices. Not to mention recent plastics.
The advanced builder/tuner have calipers. If not, then time to invest. Under $30.00 and you can be unstoppable.
Return to Slot Car News!
