Home Racing World • View topic - New Paul Gage Tires
New Paul Gage Tires
Forum rules
New Paul Gage Tires
Postby HomeRacingWorld » Wed Sep 03, 2014 7:16 pm
Few new sizes are out now.
Tested them all the past couple days. Excellent fit and performance as you would expect.
Well done!
Re: New Paul Gage Tires
Postby SRQSloter » Wed Sep 03, 2014 7:33 pm
Yeah you guys converted me. I am starting to like these tires. I just wish he had a web site. I don't do ebay.
SRQSloter
Postby scatman » Wed Sep 03, 2014 7:42 pm
scatman
Postby SRQSloter » Wed Sep 03, 2014 7:48 pm
That's where I been getting them. If there is a size I need and they don't have. Then I'm screwed.
SRQSloter
Postby WB2 » Wed Sep 03, 2014 8:22 pm
Is there a big difference between the Lola T70 tire and the Classic tires I've been using?
WB2
Postby Fast Co. » Wed Sep 03, 2014 8:26 pm
Great tires!
Fast Co.
Postby HomeRacingWorld » Wed Sep 03, 2014 8:27 pm
Slightly wider is all.
SCC is always updating to new sizes.
LEB Hobbies and Carrera Slots also carry them.
One thing to try and remember is that one size of these tires can fit many wheels with a little stretching.
Example:
The 22125 tire shown above fits the 17 wheel but also fits the smaller 15 size wheels. It just stretches over and just need to true a little.
Once you start working with his tires, you will get to know what fits what pretty fast.
Postby HomeRacingWorld » Wed Sep 03, 2014 8:33 pm
Same 22125 tire on 15x8.
Postby Fast Co. » Wed Sep 03, 2014 8:40 pm
Paul's tires are great. They true easily, wear well, can be stretched to fit a number of different wheel sizes and grip like a gorilla. What more can anyone want from a tire?
Fast Co.
Postby paul gage » Wed Sep 03, 2014 9:08 pm
Hi Guys, thanks Harry, just wanted to add that the LM series has a larger (13mm) unmounted diameter... the PGT-20125LM is 2mm larger than the PGT-20125. However, if you mount them both on a 17x10 they will be the same diameter. Why you ask, because 17x10 is getting small by comparison to the new wheels been used on modern LM & GT cars. It won't be long before we have 18x10 and even 19's. The current series (PGT Classics?) of tires with 11mm inner bore are just too small to make the stretch and there is a performance drop off after a certain point of elongation. I have found that the PGT-20105LM on a 17x8 yields superior performance than either the PGT-20105 or the XPG-20105.
Another benefit of needing less stretch is they mount much truer on RTR plastic wheels.
The original size ranges won't change because there are tons of slot cars with 13" to 15" scaled wheels. The LM's are purposed for the larger Grp 5 and modern DTM and LeMans cars using 19" to 24" wheels...
In particular, these sizes will yield superior performance on all alloy wheels with a bead diameter greater than 13.5mm....
I'll try and add some pics later...
paul gage
Postby HomeRacingWorld » Thu Sep 04, 2014 7:47 am
Thank you Paul for taking the time to chime in and provide valuable information.
SCC has these tires soon to arrive.
SCC Canada just had them come in.
Postby Nor Cal Mike » Thu Sep 04, 2014 10:24 am
I really like how our modern aftermarket tire selections now include realistic sidewall profiles rather than the slab sides that we were subjected to in the past. I never was a fan of slap sided tires. Thanks Paul for your great selection of tires.
Z Best,
Mike
Postby SlotCarCorner » Thu Sep 04, 2014 7:01 pm
Just a quick update - SCC received our PG tire order today. We now have most 1:32 PGT and XPG tires in stock including the new LM series.
:D
SlotCarCorner
Postby sixtiesracer » Thu Sep 04, 2014 10:18 pm
Dickie,it's been a while.What is the LM Series? What cars are allowed, chassis, motors , what years does it include?? You know you've piqued my interest :bow-blue: :bow-blue: :bow-blue:
sixtiesracer
The Rustinator
Postby HomeRacingWorld » Thu Sep 04, 2014 10:21 pm
It's a new line of tires from Paul Gage, not a race series sir.
Return to The Tire Shop
