There two sizes I would advise:
19125LM for slip on an go. Almost identical size as stock. Slight crown but that will wear down with light sanding or just racing depending on your surface.
For those that will true the wheels, install the tires and true again? This is my personal choice. Sanding/truing will bring down the outside diameter as well as add a little more width.
