Paul Gage Tires for Carrera Chevelle
Forum rules
Postby HomeRacingWorld » Fri Apr 13, 2018 11:28 am
Just in, the tires for this car if you need them.
Re: Paul Gage Tires for Carrera Chevelle
Postby RazorJon » Fri Apr 13, 2018 11:59 am
those hogs might go good on a dirt track car :text-thankyouyellow:
Postby Broman62 » Fri Apr 13, 2018 6:53 pm
Oh yeah baby!!! Thanks Harry!! :auto-driving: :auto-driving:
Postby chrisngreg » Sun Apr 15, 2018 9:14 am
Doe anyone know if the new Chevelle is just a minor update from the older Chevelle? Are the new tire dimensions (front and rear) the same as the older style? If so, this would be a good option for those with the older style because if I recall, the recommended PGT's were close but not quite the same size as the OEM's which are impossible to find.
Thanks
Greg
chrisngreg
Postby HomeRacingWorld » Sun Apr 15, 2018 9:31 am
Not the same wheels. These are the slightly larger and wider "hot rod" wheels like we have seen in the past.
Personally never had an issue with the PG's for the first release back in 2009 (21093XXD). Little sanding and they were fine.
Return to The Tire Shop
