Fly Panoz G T tires
Forum rules
Fly Panoz G T tires
Postby loosewheel » Wed Jan 25, 2017 5:31 pm
The S C C tire selector calls for 20138 L M for my Panoz, but they would be too wide. The stock tires are only 10 wide. Do you have a suggestion for something that will fit under the fenders?
Thanks in advance!
loosewheel
Re: Fly Panoz G T tires
Postby docdoom » Wed Jan 25, 2017 8:10 pm
You could always sand them.
docdoom
Postby HomeRacingWorld » Wed Jan 25, 2017 8:29 pm
Must have a different Fly Panoz than my collection. The wheels are 10.20 wide themselves and the tires listed fit just fine. The tires aren't tucked under the bodywork anyway?? Unless you have modified the body for it to sit that low.
If that is the case, then as suggested..install the tires and use a emery board and under power you can profile the sidewalls to fit.
Postby loosewheel » Wed Jan 25, 2017 11:40 pm
I'll give it a try.
Thanks
loosewheel
Return to The Tire Shop
