Home Racing World • View topic - Ninco Indy Car Tire
Ninco Indy Car Tire
Forum rules
Ninco Indy Car Tire
Postby WB2 » Sat Sep 10, 2016 5:54 pm
Playing with PGT tires for this car.
Paul recommends the 21128. I tried an XXD version of that tire. Too concave due to the deep rim groove, but also looked narrow.
Tried 21127. Fit good; right diameter; but too narrow compared to OEM rubber.
Tried 20137 LM. Width was better, but diameter too smalland the LM sidewall was too narrow.
So...it looks like what I want is a 21137, but he doesn't make them in a standard sidewall.
Any suggestions to duplicate the big fat wide look?
Would the 22166FF for the Fly F1 cars work?
How about the Slot.it F1 tire?
FYI the rim is 14mm overall diameter, rim diameter is a bit less than 12mm, overall width 12mm, and rib is 7mm. Mounted tire size is 21mm diameter, 13mm wide, 11mm contact patch, and a 5mm sidewall.
Thanks.
Dave
WB2
Re: Ninco Indy Car Tire
Postby HomeRacingWorld » Sat Sep 10, 2016 6:18 pm
Postby WB2 » Sat Sep 10, 2016 9:49 pm
Looking for a wider contact patch.
It's an open wheel car, ya know.
WB2
Postby HomeRacingWorld » Sat Sep 10, 2016 9:59 pm
Yes I'm aware.
Then perhaps 22168? That a big tire we use on the mods.
I would go 8 on the rib width. They seem to fit better on a smaller rib than say the 6.
Return to The Tire Shop
