1/24 Mini Challenge Proxy_Front wheel drive - interest?
Postby VTECFOUR » Fri Sep 21, 2018 12:44 pm
Throwing out this feeler for participation in a 1/24 Mini Challenge Proxy that's intended to be a builder's challenge. The kicker is that cars must be front wheel driven only!
I've built a test car and know it'll work and is fun to drive.
Basic guidelines
- wheels/tires must be front driven
- body must be from the Tamiya 1/24 kit
- motor limited to 21K
Location
- Vancouver, British Columbia,Canada
Tracks
- Greater Vancouver Slot Car Club (GVSCC) tracks numbering four and possibly five
Date
- Entry arrival by early February 2019 for track running to begin a week later
Duration
- six weeks to complete as track venues are within the Greater Vancouver region for timely running, reporting and return of cars
Entry fee
- $25 USD
Any interest out there?
VTECFOUR
Re: 1/24 Mini Challenge Proxy_Front wheel drive - interest?
Postby Lou E » Sat Sep 22, 2018 5:04 pm
I would love to do this but it seems every proxy I sign up for I can’t get a car done in time...
Count me in for a tentative yes.
Lou E
Postby viejoronnie » Sat Sep 22, 2018 7:03 pm
I'm tentatively in too.
Are'nt 1/24 Tamiya mini kits OOP and kinda spendy...at least on the bay?
Is a 4WD mini acceptable, or just traditional front drive only?
Any no-brand Chinese motor at all with no more than 21k rpm at 12 dc? Single guide pin rather than guide flag OK? "Full" interior required or is a flat card tray with driver shoulders and head ok?
Any suggestions for wheels and tires that approximate scale sizes of 10"-13" rims?
viejoronnie
Postby Z-carfan » Sat Sep 22, 2018 8:18 pm
There is a few Tamiya Minis on the bay under $30.00. I’m trying to decide if I want to do this one, I’m in so many now as it is.
Postby VTECFOUR » Sat Sep 22, 2018 10:31 pm
@ viejoronnie - answers to your questions
Aren't 1/24 Tamiya mini kits OOP and kinda spendy...at least on the bay?
I'd venture to say the kits are still available online. Whether they're expensive is a matter of opinion. There's a modeling aspect to this proposed proxy and you won't find a better scale replica than Tamiya's version.
Front wheel drive only.
The motor would have to be identifiable (Slot It, NSR, etc.) to be 21K and under. A pin guide would be fine. Flat tray with driver figure is OK too.
As below you'll notice a 20mm x 10mm max spec will be allowed so any 15 x 8 rim with tires could be made to fit. I used the BRM 1/32 Nascar 14.5 x 8.9 rims with home made urethane tires on my prototype.
Here are some other guidelines that'll be in place.
Wheels/Tires
- maximum combined diameter - .787" (20mm)
- maximum width - .394" (10mm)
- urethane tire composition only
I've based the maximum combined diameter by scaling down the 12" rims and tires on my 1:1 Mini which are 19 inches tall. That works out to .792" in 1/24th scale.
Minimum chassis to track clearance
- .0625" (1/16", 1.587mm)
Here are a couple of the GVSCC tracks to be run on.
Luf's Big Targa
Mike's YVR Runway
If there any other questions, just ask.
Still gauging interest by spreading the word on other forums and talking to slot car colleagues throughout Canada and the USA.
VTECFOUR
Postby viejoronnie » Sun Sep 23, 2018 3:58 pm
In order to keep my own build budget manageble, I think I will use a slightly lengthened, reversed 1/32 Artin plastic chassis/axles and wheels with a suitable motor of known ancestry and simple fixed pin/blade guide. I plan to add brass or lead weight to the inside of chassis outrigger boxes to lower the CG, since the stock Artin chassis/wheels are already set up for very low under-chassis clearance.
I will keep an eye out for Tamiya kits and build one that represents the 1:1 Austin mini beater I campaigned in the late 60's, red primer and all.
My 1:1 Mini racer was not competitive, and this wont be either, but both are fun to mess with.
viejoronnie
Postby VTECFOUR » Sun Sep 23, 2018 5:26 pm
VJ, you're right on with the spirit of creativity and ingenuity, what this proposed proxy is about.
Motor layout is wide open, sidewinder, angle, inline, as longer as the front wheels are what's providing the drive.
One of the known scratchbuild chassis gurus gave me the idea. "We know how to build a rear drive chassis, but how about a front one? All those fundamental factors that we followed get thrown out the window and you have to learn and discover new ones."
Brilliant! This is a challenge.
We'll see if we can get this this off the ground.
Thanks for your interest.
VTECFOUR
Postby viejoronnie » Sun Sep 23, 2018 9:44 pm
In keeping with my goal of a budget racing mini, I have researched the OEM Artin motor that came with my donor chassis. The white end bell 13,000 rpm 12v Artin motor, has been accepted for other HRW proxy races. Is this motor, that won't beat anybody, acceptable?
viejoronnie
Postby VTECFOUR » Sun Sep 23, 2018 11:25 pm
Your Artin motor choice would be fine.
VTECFOUR
Postby viejoronnie » Mon Sep 24, 2018 12:54 pm
Good deal.
viejoronnie
Postby TuscoTodd » Mon Sep 24, 2018 11:07 pm
Definitely a slick idea! Depending on timing, I may have to look into participating in this one as well as I have never tried to build a FWD slot car!
Postby viejoronnie » Wed Sep 26, 2018 8:07 pm
Picked up a few Scaley motors to upgrade from the Artin motors I was considering using.
viejoronnie
Postby VTECFOUR » Thu Sep 27, 2018 11:58 am
Not really enough interest, so this goes on hold. A number of us at GVSCC will build regardless and have a fun run.
Thanks to those who expressed interest.
VTECFOUR
Postby Lou E » Thu Sep 27, 2018 12:05 pm
Working on a chassis in Tinkercad, if I get the thing together by February I’ll send it to you to see how it does against whatever you guys come up with.
Lou E
Users browsing this forum: No registered users and 51 guests
