Home Racing World • View topic - HRW Land Speed & Drag fun run!
Postby TuscoTodd » Fri Mar 27, 2015 2:36 pm
(this is a continuation / expansion of the fun we had with the P-BOP proxy cars here: viewtopic.php?f=35&t=10619&p=124788#p124788)
This Fun Run is just as much about the building and modeling as it is about the performance! :D
Classes:
- Pre '65 Hot Rod
- Pre '65 Gasser
- Pre '65 RatRod
- Sling Shot style rail (front motor, driver over/behind the rear tires)
- Pre '65 Salt Flats / Land Speed record type
----- Class A - H&R Lightning II 40,000rpm Motor
----- Class B - Piranha 21,500 Motor
Requirements for all cars/classes:
- No limit in the number of cars that can be entered by a builder! Want to enter one in each class? Want to enter 3 in one class and 2 in another? Roll them on into the staging lanes as it is definitely a case of the more the merrier for this fun run!
- 1/32 scale cars only
- No lexan bodies/drivers
- Urethane/Rubber tires only
- Appropriate looking wheels / inserts
- Chassis - wide open with the exception of NO factory drag chassis being allowed. Ideally we would love to see everyone try their hand at building a chassis from scratch. (great time to try your hand at fabbing one from brass, plastic, wire, wood, paper mache, etc!)
- Each entry must have a minimum of four functional/rotating tires (not counting wheelie bar wheels)
- .050" min ground clearance
- Guide flag blade can not exceed 1" in length - drop arm, spring loaded, etc designs are allowed to compensate for front end lift
- Wheelie bars are acceptable - however they must meet the following requirements
------ Bars must be of appropriate scale size and must not exceed 3" in length from the middle of the rear axle (if used)
------ Bars must be of the dual wheel design and have the wheels spaced wide enough that the wheels do not ride on the braid
------ Bar "wheels" can not be of the "fixed/skidder" type design (potential track damage) or be overly large/non-scale in appearance (modeling aspect)
- Gearing: Open to builder's preference
- Motor: Noted by classes below
Class specifics
- Pre '65 Salt Flats / Land Speed cars will be measured first on trap speed second on elapsed time (all other classes on elapse time then trap speed).
- Max width 2.5"
- Motor:
----- Class A - H&R Lightning II 40,000rpm motor only!
----- Class B - Piranha 21,500rpm motor only!
- Max width 2.5"
- Motor: H&R Lightning II 40,000rpm motor only!
- Pre '65 Hot Rod
- Max width 2.75"
- Motor: Piranha 21,500rpm motor only!
- Pre '65 Gasser
- Max width 2.75"
- Pre '65 RatRod
- Max width 2.75"
Intended format:
- Tires to be cleaned prior to each round.
- Preliminary qualifying to be performed to set bracket for each class
- Cars to be launched by a single driver using a common control to eliminate driver to driver variance.
- Quickest car advances to next round.
Please note:
- There is NO entry fee for this fun run other than the cost of shipping your car to the first venue.
- The car hosts will be providing photos and reviews of the cars for everyone's enjoyment! :)
- Concours judging will be performed at the first track at a minimum. :handgestures-thumbup:
If you are interested in participating and/or hosting - please let me know (user name, class(es) and car make if available) and I will add your info to the list below!
Thanks! :handgestures-thumbup:
- REVISED due date is now[color=#BF0000]
[color=#00BF80]
Mark's Model World - 55' (1760 scale feet) - plus shut down area
Route 93 Raceway - 55' (1760 scale feet) - plus shut down area
Sun City Drag Strip - 41.5' (1320 scale feet) - plus shut down area
Bullitt Speedway in Louisville - 55' (1760 scale feet) - plus shut down area
TuscoTodd - All five classes - (streamliners for both LSR cars, '41 Willys gasser, others to be determined) :dance:
ShotgunDave - All five classes ('41 Chevy Gasser, VW Bug (Hot Rod), other cars to be determined)
RetroRacer44 - AA Altered Fiat Topolino (Gasser), '53 Studebaker (Land Speed - Class B)
HomeRacingWorld - RatRod
Btaylor - Streamliner #2 (Class A), Studebaker #461 (class A), (2) Streamliners #'s to be determined (class B), Sling Shot Rail, possible Gasser entry
Slotguy - '64 GTO (Hot Rod?)
Slot Therapist - '49 Ford Tudor Gasser and possible Sling Shot(?)
nhdungeonracer - '55 Chevy (Hot Rod), '30 Ford (Gasser)
Foamy - Salt Flats/Land Speed, '63 Vette (Hot Rod)
Austin - Coupe Gasser, '57 T-bird (Hot Rod)
HRWJim - Gasser
Ky.Slot Racer - '55 Nomad (Gasser), mid 50's style Sling Shot, '59 Impala (Hot Rod)
Bookie - '41 Willys (Gasser) '56 Corvette (Hot Rod)
Racie35 - Slingshot
Gameover - '64 Cuda (Hot Rod)
And our participants in a little easier to follow format...
Re: HRW Land Speed & Drag fun run!
Postby Retro Racer 44 » Fri Mar 27, 2015 3:10 pm
I'm in! Does an AA Altered Fiat Topolino count as a pre 65 Gasser? I have never followed drag racing that much so am not sure where the lines divide between classes.
Retro Racer 44
Postby DAVE » Fri Mar 27, 2015 3:24 pm
I would go with JK retro Hawk motors rather than the Pro-Slot FK. The pro-Slots
sometimes wont start on their own and require a very high amp power supply.
We have had problems with them in hardbody racing.
DAVE
Postby Retro Racer 44 » Fri Mar 27, 2015 4:47 pm
I had the first picture in mind, so I guess i'm good to go.
Retro Racer 44
Postby TuscoTodd » Fri Mar 27, 2015 9:08 pm
Postby TuscoTodd » Fri Mar 27, 2015 9:23 pm
Postby Retro Racer 44 » Sat Mar 28, 2015 1:38 am
I am considering a slingshot dragster as well, and maybe a hot rod, but we will see. How far off are we putting the start of this? There is a lot of building to do in somewhat unfamiliar territory.
Retro Racer 44
Postby TuscoTodd » Sat Mar 28, 2015 6:13 am
Keith -
I set the "Due Date" for the cars as June 19th. That should give everyone plenty of time. :)
Thanks!
Postby HomeRacingWorld » Sat Mar 28, 2015 6:35 am
Ratrod for me :)
Well done.
Postby TuscoTodd » Sat Mar 28, 2015 6:44 am
Thanks Harry!
Have you added to the list!
:banana-dance:
Postby btaylor » Sat Mar 28, 2015 6:47 am
I assume that period correct streamliners are legal in the land speed class? This is my entry and reference photo.
and this is what I have so far
Postby TuscoTodd » Sat Mar 28, 2015 7:01 am
Bob! That looks AWESOME!!!
Yes - period streamliners are definitely allowed! :banana-dance:
I will get you added to the list!
Thanks!
Postby btaylor » Sat Mar 28, 2015 7:08 am
Todd, I am doing a rail dragster, and a either a gasser or hot rod too. Question, is the lightning motor double ended? I have never even seen one!
Postby TuscoTodd » Sat Mar 28, 2015 7:37 am
Bob -
I will add the dragster to the list!
And the Lightning motor is a single ended FK style - here is a picture:
(here is a shot of it from the Cloverleaf site as well: http://cloverleafracing.com/product_inf ... cts_id=439)
Postby btaylor » Sat Mar 28, 2015 7:42 am
Thanks Todd, I have some ordered, but I need to set up the chassis with something else till they get here. should be another motor in my box that's similar in size and shape.
Users browsing this forum: No registered users and 115 guests
