RAA - Round #4 - The River Run
Postby Audi1 » Wed Jan 17, 2018 3:00 pm
We ran the qualy on the RAA cars today. Below are the results and comments from the runs. Quite a difference between the cars, but not necessarily between the classes. On this technical track, drivability is the key to winning, as several of the GT-2 cars outperformed their bigger GT-1 brothers.
1. #5 - GT-1 - Aloha - 6.920 - super smooth and quiet, nice set-up, well balanced, easy driver
2. #33 - GT-1 - Brumos RSR - 6.964 - very fast, unbelievable brakes, some tire chatter, well balanced
3. #40 - GT-2 - Lance - 7.022 - some chatter, balanced, predictable, good driver
4. #73 - GT-1 - spiritracer - 7.090 - fast, rear hops under acceleration, tails-out in corners, but predictable driver
5. #8 - P - spiritracer - 7.118 - Some anglewinder hop, good balance, some tire chatter in the corners, easy driver
6. #74 - GT-2 - austin - 7.193 - very fast on straights, struggles some for grip in the corners, well-balanced
7. #16A - GT-2 - Aloha - 7.225 - very nice car, smooth, well balanced, easy driver, wife thought it looked very Bad-A--
8. #50 - GT-2 - Lance - 7. 279 - well balanced, some chatter in the corners, easy driver
9. #32 - GT-1 - Bov - 7.327 - quick but twitchy, strong motor, predictable handling
10. #86 - GT-2 - arroldn - 7.427 - smooth, some chatter in the corners, predictable driver
11. #61 - GT-1 - arroldn - 7.544 - fast in a straight line, rear hops on acceleration, struggles for grip in the corners
12. #99 - GT-1 - ALS - 7.548 - smooth, but uneven acceleration with rear tire hop, good balance
13. #41 - GT-1 - Bov - 7.618 - smooth, well-balanced, easy driver, some chatter in turns, could use more motor
14. #15 - P - Austin - 7.672 - a little loose, rears feel out of round, hops rear on acceleration, good speed, maybe too much motor(?)
15. #215A - Austin - 7.855 - needs more motor or taller gearing, some chatter, good balance
16. 33 - GT-2 - spiritracer - 7.862 - very smooth, easy driver, could use taller gearing. runs to max speed very early on straights
17. #9 - P - arroldn - 7.913 - too much motor, anglewinder hop on straights, a lot of gear noise when the motor spools up, struggles for grip in the corners
And that's how they shook out; GT-1 class on top, but with the GT-2 class looking strong, overall. We'll see what unfolds on Sunday at the race. The race will be run in reverse qualifying order. Results by the end of the day on Sunday, along with more comments and pics of the field/race.
Re: RAA - Round #4 - The River Run
Postby Austin » Wed Jan 17, 2018 4:06 pm
Not all the cars are there ???????
Austin
Postby Austin » Wed Jan 17, 2018 4:13 pm
These are the cars that should be there. ???????
Austin
Postby Audi1 » Wed Jan 17, 2018 9:26 pm
So, I appear to be missing 5 cars................ I'll look for them tomorrow!
Postby Audi1 » Thu Jan 18, 2018 6:49 am
Take heart, racers..........the missing cars have been found! - "hiding", as it were, under a false bottom that Monte (kidvoltage) constructed in the bottom of the shipping box (AKA a 3rd layer of cars.......). I'll run the qualy on them today and post the results tonight. Sorry for the delay in these last 5 cars.
Postby kidvoltage » Thu Jan 18, 2018 7:40 am
Sorry Allan, too many nights watching the Curse of Oak Island.
"Keep digging, it's down there somewhere!"
kidvoltage
Postby Audi1 » Thu Jan 18, 2018 3:07 pm
Qualy results for the remaining 5 cars have been added to the first post on this thread. Race on Sunday!
Postby bov » Thu Jan 18, 2018 5:19 pm
I preferred the first version - I wasn't so far behind........
Thanks for hosting the round, well done to the quickies - but the race isn't over yet.....
bov
Postby Brumos RSR » Thu Jan 18, 2018 5:26 pm
Thanks for the qualifying Allan, hopefully the brakes will not fade on Sunday and deslots will be at a minimum for the #33. That's what it will take to compete with the Distinguished Gentleman of Hawaii. Good Luck to all the builders on Sunday.
Brumos RSR
Postby Audi1 » Sun Jan 21, 2018 2:00 pm
And here are your results for Round 4 in this year's Race Across America.
But first, a couple of shots of the staged cars, the track and the field.
The cars were run for 3 minutes on each of 3 lanes, for a total of 9 minutes racing. The track voltage was set to 10V. The track was vac'd and wiped down with a tack cloth just prior to the start of the Round. All cars had their tires cleaned on a sticky pad before entering into their first heat, and again between heats.
When the smoke cleared, this was the finishing order:
Position / Car # / Class / Racer / Total Laps / Fast Lap Tiebreaker (If needed)
1. #5 / aloha / GT-1 / 76.5
2. #8 / spiritracer / P / 76.2
3. #16A / aloha / GT-2 / 75.0
4. #73 / spiritracer / GT-1 / 74.2 / 6.699
5. #33 / brumos RSE / GT-1 / 74.2 / 6.752
6. #74 / austin / GT-2 / 74.1
7. #50 / Lance / GT-2 / 73.5
8. #32 / Bov / GT-1 / 72.7
9. #41 / Bov / GT-1 / 70.9
10. #99 / ALS / GT-1 / 69.9
11. #9 / arroldn / P / 69.3
12. #86 / arroldn / GT-2 / 68.5
13. #15 / austin / P / 68.3
14. #3 / spiritracer / GT-2 / 67.2
15. #215A / austin / GT-2 / 66.8
16. #61 / arroldn / GT-1 / 65.8
17. #40 / Lance / GT-2 / 6 - DNF
And here's your podium for the Round:
A big day for aloha with a sweep of the GT-1 and GT-2 classes and the overall win! And a good day for spiritracer, too, with a win in the P class. Congrats to the podium and all the cars in this Round! :text-bravo: :text-bravo:
We did, unfortunately, have on break-down that could not be repaired. Lance's Ferrari F-40 stopped running after 6 laps in it's first heat. At first we noticed that the car seemed to be running intermittently on the back straight. We adjusted the braid, checked that the gears weren't binding and set it back on the track. It ran, again, intermittently for another 1/2 lap before coming to a stop. We opened the car and checked both the leads to the braid and to the motor - both fine. So, at this point, it looks like the motor has had a problem. I'll return the car to Lance if he sends me his shipping address; then he can re-join the proxy after checking his car out.
Where to for the next Round, Austin?
Postby arroldn » Sun Jan 21, 2018 3:50 pm
Thanks Allan for a good race in the RAA. Next.
Congratulations to our top 3 podium finishers. 2nd, 4th and 6th for my cars. Well at least they had something in common, even numbers. :lol:
Arrold
arroldn
Postby bov » Sun Jan 21, 2018 3:54 pm
Hi Alan,
Thanks for hosting the round!
Congrats to Dale and all the other Podiumites.......
Good to see the photos, too!
bov
Postby Brumos RSR » Sun Jan 21, 2018 8:28 pm
Thank you for hosting and putting together a team to provide us with a great round. Congratulations to the Distiguished Gentleman from Hawaii. I thought it would take a perfect run to beat the 5, but I didn't even factor in the same to beating the 16A!!! Congratulations also to Spiritracer and the in class podium builders.
Brumos RSR
Postby Aloha » Sun Jan 21, 2018 11:46 pm
Thank you to the group for getting together and finishing this round on River Run. We can see that it is a technical track. To all the participants may this Proxy continue to grow back to its prowess of time past. Austin thank you for keeping this alive. Onto the next round.
Aloha
Dale
Aloha
Postby Audi1 » Mon Jan 22, 2018 10:23 am
Good news - Lance's Ferrari turned out to have a bad lead connection (broken wire at the guide end), which was repaired this AM. The car is back in racing trim now and The #40 is moving on to the next Round with the rest of the cars.
Austin - where do I send them next?
Users browsing this forum: No registered users and 50 guests
