Home Racing World • View topic - 1:24 Classic Steel Wheels 1/8'' Axle - Silver (Center Rib)
Postby Austin » Sun Feb 12, 2017 5:54 am
These tires fit great on these wheels PGT 1/24 H&R Narrow (Rib)
Will you be making wheels for these tires ?
PGT 1/24 H&R Wide (Rib)
Austin
Re: 1:24 Classic Steel Wheels 1/8'' Axle - Silver (Center Ri
Postby Norman » Sun Feb 12, 2017 10:54 am
What Don said! :text-yeahthat:
Norman
Postby SlotCarCorner » Mon Feb 13, 2017 11:09 am
The short answer is "Yes." However, there are some other projects in the pipeline that are higher on the list at the moment. When they become available, HRW readers will be the first to know.
:text-thankyouyellow:
SlotCarCorner
Postby Norman » Fri Jun 01, 2018 9:37 am
Any info on when the wider wheel with rib will be made?
Thanks, guys!
Norman
Postby SlotCarCorner » Fri Jun 01, 2018 3:55 pm
Hello Norman,
Classic Steel 15x10mm will be next (early Summer) followed by the wider 1:24 Classic Steel Wheel (late Summer).
Thank you for your patience!
SlotCarCorner
Postby Fathead59 » Thu Jul 26, 2018 1:04 pm
Will be keeping an eye on the slot car corner web site for those wheels, have a couple of cars I am building, two are stock cars and two will be drag cars using Ean edge drag chassis
Fathead59
Postby Fathead59 » Thu Jul 26, 2018 1:05 pm
I have so many projects to finish don't know which ones to do
Fathead59
Postby Broman62 » Thu Jul 26, 2018 7:20 pm
Users browsing this forum: No registered users and 41 guests
