Blue Ridge Parkway 2 lane routed
SHOW YOUR SLOT CAR TRACK!
Re: Blue Ridge Parkway 2 lane routed
Postby Burrell » Sat Apr 08, 2017 6:21 am
You did a great job. In my research I had found some pre-made that looked correct, but I couldn't find any large enough to span over two slot car lanes (I use Carrera track). But yours look authentic and probably better than a premade tunnel anyway. Thanks for the info.
Dangermouse wrote:Hi I made the tunnel entrance myself. I used some high density foam board. I drew out the design cut it with a sharp knife and then etched the bricks/rocks into it with a blunt pointed tool.
I then coat with white PVA glue (wood glue) and sprinkle very fine sand over the glue. Once dry paint grey and dry brush with white and burnt sienna and umber to weather as desired.
I can take a photo of the foam board if you need me to.
cheers
David
Burrell
Return to Reader's Roads
