Home Racing World • View topic - Show your track! - 2017
SHOW YOUR SLOT CAR TRACK!
Re: Show your track! - 2017
Postby Broman62 » Thu Dec 07, 2017 6:38 pm
Great thread here...all cool layouts...new or old!!!!
Postby Ky.Slot Racer » Thu Dec 07, 2017 8:15 pm
Last edited by Ky.Slot Racer on Wed Jul 18, 2018 6:22 am, edited 2 times in total.
Ky.Slot Racer
HRW Master Modeler
Postby Rleog » Fri Dec 08, 2017 5:46 am
Rleog
Postby rick42 » Sat Dec 09, 2017 7:09 pm
Starting back in the hobby. I am starting with carerra 132 and 124 scale track and cars. Just remodled a building behind my house for a slot car room. Its 10 by 19 feet. Not much but it is what it is. I have ordered an adjustable power supply , numerous track pieces and all kinds of other goodies to get the 2 sets I already have to where I want them. Had the itch pretty bad so I had to set up a temporary track. Started painting the track , so some pieces are painted and some are not. Evereything I ordered should be here early next week , so I will be taking it apart and finishing the paint job next week. Here are 2 of the tracks I have set up just to calm the itch. And yes Ive changed the table up 3 times already. And probably will again.
rick42
Postby 73emgee » Sun Dec 10, 2017 7:14 am
73emgee
Postby vins123 » Sun Dec 10, 2017 11:27 pm
vins123
Postby bobbyraz49 » Mon Dec 11, 2017 2:53 pm
bobbyraz49
Postby War Eagle River » Mon Dec 11, 2017 5:26 pm
85ft. 4 lane Ninco. 16''x8.5', Don't need scenery, got 270* of it! All 4 lanes individually powered. FB--War Eagle River
War Eagle River
Postby slowshoes » Mon Dec 11, 2017 6:44 pm
slowshoes
Postby Z-carfan » Mon Dec 11, 2017 8:37 pm
I updated my track post with my 2 lane Carrera 'Bertrand 8' layout. Just got running this weekend so I can break out some cars.
I will need to tweak a little and set up some man made borders for the tighter corners, the 1/24's like to drag the inside wheel off track. :P
Postby War Eagle River » Tue Dec 12, 2017 5:17 am
War Eagle River
Postby valie » Tue Dec 12, 2017 7:23 am
valie
Postby bobbyraz49 » Tue Dec 12, 2017 3:32 pm
What is best for cutting MDF ? Scroll saw? Circular saw ?
bobbyraz49
Postby Pappy » Tue Dec 12, 2017 4:15 pm
Depends on what shape you are cutting. Just about any saw or router will do a good job on MDF when using a fine tooth blade or carbide tipped router bit. I use a sabre saw for curves and a table saw or miter saw for straight cuts. If you are using a router with a template guide you can cut either straight cuts with a straight board for a guide or curved cuts with a curved template for a guide. Or you can mount a router to the end of a straight board with a pivot point for the radius of cut you want and use it like an arm to swing the router around the center point of the arc you want.
Hope this helps
Pappy
Postby bobbyraz49 » Tue Dec 12, 2017 7:47 pm
bobbyraz49
Return to Reader's Roads
