REAITY MOD TOUR, EAST COAST CUSTOM CARS 150
Post Your Club/Home Info Here
Postby Beach Oval » Mon Jan 20, 2014 7:27 am
The REALITY MOD TOUR will be RACE #5 of 6 @ BEACH OVAL in SOUTHAMPTON NY February 15th
$20.00 Entry Fee
TOP 3 PAYOUT
50-50 RAFFLE
FOOD and DRINK Provided
REALITY MOD TOUR RULES APPLY
6 LANE 10x20 TRI-OVAL
8 Cars in MAIN EVENT running a 25 Lap Per Lane in a CHAMPIONSHIP ROUND ROBIN LAP FORMAT
All MODS will QUALIFY for time to break down HEAT RACES
HEAT RACES will follow with Winners advancing to MAIN
A CONSI will follow HEAT RACES to Determine who advances to main.
SUPER MODIFIED Race to follow
Reality Modified Tour Rules updated 01/11/2014
# 1. Body: Approved asphalt type modified body. Bodies made by Reality Raceway ( Tour Only ) . No modifcations. All cars must have a Drivers Head and Air Cleaner. It is intended that these cars look as realilistic as possible. All new bodies will come thru with windshields and rear panels and must remain. Rear panels on mods required.
ONLY controller allowed in drivers area during races. Straight wired controllers only. No electronic devices between track and controller handle.
# 2. Chassis: PARMA # 577 only. Chassis must be cut to pattern. Pattern can be supplied.
MUST BE APPROVED. .. NO PAINT or Tape on CHASSIS BOTTOM that interfers with chassis gauge
Wheelbase 4".. + - 1/8".
Front wheels may spin independently. Must have soild steel axles front and rear. Minimum axle dia. 1/8 ".
Axle holes may be slotted. Bushings may be filed.
All cars must have rear bumpers made from 1/8 - 3/16 " channel, square, or rectangular brass only. Rear bumper Minimum ht. 3/8 "
All cars must have side bars 1/16 " dia. max/ brass only. Max. width of bars is 3-1/4 ". Tolerence is + - 1/16.
All bars must be approved.
No other chassis modifications.
No drilling or lighten of chassis. Weight may be added.
Chassis Clearence is .047min.
# 3. Spacers: The ONLY SPACERS that will be used are the the following SONIC spacer in their respective locations. No alterations.
Left Frt.- One- .062. (optional)Sonic spacer. Part # SON-062
Right Frt.- One- .160. Sonic spacer. Part # SON-.160
Right Rear. Two- .160. Sonic spacers. # SON-.160
Left Rear. One- .160. Sonic spacer. # SON-.160
# 4. Tires: ALL Tires.. Pro-Trac Daytona Stockers ONLY. Nail Polished allowed.
Chassis Clearence is .047min. Tour Rule. Checked at Track Chassis height station. All 4 tires will touch chassis gauge.
All Front Tires MUST TOUCH TRACK
Front and Rear Tires.. Maximum wide is .800. Minimum wide .700.
Minimum Dia. is .750 measured inside & outside.
Maximum Dia. is .880.
# 5. Motors: The motors allowed in these cars will be the Falcon 7 , JK Hawk 7, Demon, Trinity
Evil 9..designed after the Falcon 7... Heat sink may be added. No Modifications. NO GEAR RULE 11/13 - 2014 ???
Beach Oval
Users browsing this forum: No registered users and 73 guests
