by olskoolslotz » Sat Mar 09, 2019 11:24 am
Yes, I got these in a motor lot and to be truthful I'm unfamiliar with 1/43 scale. I did find a description for MH417A motors showing them as 19,000 RPM at 6V. One motor in my photo at the top right is marked MM413A, this one I acquired from someone to try out at some point. On the Electronic Goldmine page the motor shown in their graphic is marked MJ413A, I can only assume these are different lot or run numbers but expect the motors to be the same spec. Maybe someone from the 1/43 group can help us both out.
