1:32 Strangebrew modifieds for sale
Used Car Salesman?
Buyers & Sellers HQ
Postby strangebrew » Mon Mar 20, 2017 11:47 am
....................................ALL SOLD..Thanks everybody............................
..................These cars are 1:32 scale.............................
First of all I'd like to state, I'm uncomfortable selling any of my builds, because I never feel they're "up to snuff".
That being said, I've spent the last 6 weeks, on these cars, & spent quite a bit of extra time getting things right.
I will guarantee your money back & I'll pay the return shipping if the buyer doesn't get what's expected!
Everything on these cars is brand new, out of the package & they have only about a dozen laps on my small oval to
ensure nothing will fall off. All the bodies are a combination resin/styrene/epoxy construction & are "one-offs".
You can PM me with questions etc.
--------------------------Thanks for looking--------------------------------
They are guaranteed to pass tech. at the HRW SHOWDOWN...................so here goes!
First up a (Ready To Run) Chevette modified:
..............................SOLD........................
Chassis is a combination 1/16, 3/64 brass rod & assorted flat brass construction.
wheelbase is 3 1/4"
Koford steel axles:
..................I prefer using 1/8 axles on my builds, so that's what you see here)...................
polished & detailed 1/2" wide Pro Track wheels:
PGT shore 40, 22160.395 rear & PGT shore 40, 22160-FF front tires:
...................(Wheels & tires glued & trued on Tire Razor)....................
Jet guide flag with Big Mama copper braid:
Piranha motor, Parma hex head motor screws:
Cox 27 tooth crown gear & Professor Motor 9 tooth pinion:
All mounted with Walther 1/4 self tapping screws:
Paint is Ace Hardware "Bright Yellow" over Ace Hardware white primer.
Decals printed by me:
Keep in mind: EVERYTHING is brand new...............All you need to do is put your "tune to it"
===================$120 shipped =========================
............................SOLD..............................
Next up is a (Ready to Run) 38/40 Ford Coupe:
(I'm kinda' proud of this one.....I don't think I've ever built a better one :D )
Chassis is a combination 3/64 brass rod & assorted flat brass construction.
Wheelbase is 3 1/8".
Koford steel axles:
Painted & detailed 1/2" wide Pro Track wheels:
Paint is Ace Hardware White overlayed with several coats of Dupli-color Clear Effects
giving it a diamond flake appearance under the lights.
EVERYTHING is brand new, just a little tune might be needed.
===================$125 shipped =========================
How about a couple of "finish it to taste" modifieds:
First is a '74 Vega:
This one is set up using 3/32 axles since most of the guys on here use them.
the wheelbase is 3 1/4" & I set it up using CB design 12m wheels with PGT 22126 tires on the rear &
CB Design 11m wheels with PGT 21126 tires on the front.
Brand new Jet guide with Big Mama braid is included.
Also included are driver figure, engine, air cleaner that fits under styrene hood scoop,
radiator & Walther mounting screws.
Complete assembly has several coats of Ace Hardware grey enamel primer.
===================$75 shipped =========================
...............................SOLD.................................
I have wheels & tires mounted to display only how the set up might look on the track.
Last one up is a 37/38 Chevy coupe modified:
I built this one using oilite bearings in the rear.
Also included are driver figure, engine/radiator/air cleaner combo.
(I added a small hood later as an after thought)
strangebrew
Re: 1:32 Strangebrew modifieds for sale
Postby btaylor » Mon Mar 20, 2017 12:19 pm
Good deal on those cars Brew! Your time on those is invaluable! Someone will be getting some nice rides.
Crossroads SUPER Speedway
Cherokee Point 80' Road course
Postby pastor bubba » Mon Mar 20, 2017 3:30 pm
I wish I had some spare money but focusing on the engine for my AMX right now. Hopefully another time.
pastor bubba
Postby challenger15 » Fri Apr 07, 2017 8:48 am
I would like to buy a 37/38 mod how is it done?
thanks wayne
challenger15
Postby strangebrew » Fri Apr 07, 2017 2:12 pm
.................................PM sent.................................
strangebrew
Postby tin_indians » Wed Apr 12, 2017 5:17 pm
pm sent about the #2 modified....seems to be stuck in my outbox though
tin_indians
Postby strangebrew » Wed Apr 12, 2017 6:05 pm
Having trouble sending you a PM...will keep trying
strangebrew
Postby oldtymer » Wed Apr 12, 2017 6:09 pm
strangebrew wrote:Having trouble sending you a PM...will keep trying
Brew....did u get my PM s ....if not I'll let you know here that I will take the #2 if available ...if not I'll take the 4..
Thanks
Fred
oldtymer
Cat Lovers Club Prez
Postby tin_indians » Thu Apr 13, 2017 5:38 pm
I'm having real troubles PM'ing you. If you still have the #2 as we discussed, I'll take it.
tin_indians
Postby strangebrew » Thu Apr 13, 2017 5:40 pm
PM sent tp tin_indians
strangebrew
Postby tin_indians » Tue Apr 18, 2017 5:24 pm
PM sent to the Brew
tin_indians
Postby tin_indians » Tue Apr 18, 2017 5:37 pm
Just sent you another PM..at 5:37 mountain time.
tin_indians
Return to FOR SALE!
Users browsing this forum: Bing [Bot], DaFisch and 3 guests
