Home Racing World • View topic - Roller Test Bench
Roller Test Bench
Roller Test Bench
Postby HomeRacingWorld » Mon Feb 26, 2018 7:59 am
Re: Roller Test Bench
Postby Z-carfan » Mon Feb 26, 2018 10:14 am
Very cool tool! Thanks for share that Harry.
Is there enough length there for a 1/24 car?
Postby SlotCarCorner » Mon Feb 26, 2018 11:52 am
SlotCarCorner
Postby HomeRacingWorld » Mon Feb 26, 2018 8:07 pm
Here are some Carrera
Now IF...and I repeat IF you feel like modifying...you can lengthen the slot to accommodate even longer models. NOTICE, I did not go all the way. I left a slight amount at the end.
So depending on where your guide is located, you can fit a larger variety on here.
Postby HomeRacingWorld » Tue Feb 27, 2018 6:10 am
Edit to show area of slot I trimmed out.
Postby SlotCarCorner » Sun Mar 18, 2018 6:30 am
SlotCarCorner
Return to SlotCar ToolTime
