Home Racing World • View topic - Simple RPM Test Rig
Simple RPM Test Rig
Re: Simple RPM Test Rig
Postby Z-carfan » Wed Jan 11, 2017 11:37 am
Perfect, thanks Harry I just ordered one of these.
Postby btaylor » Wed Jan 11, 2017 11:47 am
Thanks Harry. I have some old broken chassis that I will make motor holders out of. the rest will be a shameless copy of yours!
Postby BARC 1 » Wed Jan 11, 2017 12:20 pm
I use the same equipment. Servo discs make good rpm discs as well. I use a strip of bare metal foil for the reflective strip.
The cost of these devices is inexpensive, and they are easy to use. Finding out exactly what rpm the motor is turning is quite easy.
Postby Broman62 » Sat Feb 02, 2019 1:38 pm
Postby bobbyraz49 » Sat Feb 02, 2019 5:43 pm
I'd like to suggest using super glue to help keep the reflective tape on the spinning gear.
The price of these tach's are good. The tach is an effective way to get rpm's. I hold the button down and see what the display states and just estimate the average.
bobbyraz49
Postby Perrotoro » Thu Feb 14, 2019 8:25 am
c'mon 4:30 - gotta go build one of these - thanks Harry
Perrotoro
Postby JULES » Thu Feb 14, 2019 9:18 am
Kids left home now? Got some spare Lego?
Here is my alternative style motor RPM and torque checker, operated and watched over by the motor police.
Jules
JULES
Postby HomeRacingWorld » Thu Feb 14, 2019 11:31 am
Well as long as the authorities are on hand :)
Postby Perrotoro » Sun Feb 17, 2019 9:12 am
- I see plenty of already posted methods
Perrotoro
Postby Broman62 » Sun Feb 17, 2019 11:29 am
Postby Perrotoro » Tue Mar 05, 2019 9:22 am
Perrotoro
Postby Z-carfan » Tue Mar 05, 2019 9:28 am
I like that setup Broman, looks like it would be much easier to swap out motors. :music-rockout:
Postby HomeRacingWorld » Tue Mar 05, 2019 9:29 am
Yes sir, well done!
Postby Fathead59 » Sun Aug 04, 2019 10:18 am
Well , it looks like I will be making a motor test bench during the winter months that will be coming
Fathead59
Postby War Eagle River » Sun Aug 04, 2019 4:29 pm
One thing to consider concerning the disc. Use as small a disc as possible. And shine the laser dot as close to the middle as you can. The closer to the shaft the beam, the more accurate the reading. I used a small aluminum disc, 3/4” diameter. Epoxied an axle stop with a set screw in it. Pained it flat black, put on a strip of reflective tape.
War Eagle River
Return to SlotCar ToolTime
Users browsing this forum: No registered users and 35 guests
