Home Racing World • View topic - Got the track off the floor!
Plastic Or Wood
All Things Track Building!
Postby olddude13 » Fri Jan 11, 2019 4:26 pm
This is our first table track we are doing Riverside Raceway
lots to do lots of fun
olddude13
Re: Got the track off the floor!
Postby olddude13 » Fri Jan 11, 2019 4:32 pm
Set the elevations and guard rails also played with the plaster cloth
Guard rails are thin azak type material pinned with 1/8 rod we will be running 1/32 and 1/24 cars on the track
olddude13
Postby williamg » Fri Jan 11, 2019 4:52 pm
Excellent.
Nice to see a little helper too. Father son time is missing in lots of kids today with phones, video games and computers.
williamg
Postby chappyman66 » Fri Jan 11, 2019 5:38 pm
Yup, looking great!
Postby dw5555 » Sat Jan 12, 2019 10:25 am
Looks good. It's nice when you can start adding scenery.
Dave
dw5555
Postby F1Fan » Sat Jan 12, 2019 11:01 am
F1Fan
Postby SpeedyNH » Sat Jan 12, 2019 7:40 pm
go wood?
pretty nice though.
speed
SpeedyNH
Postby olddude13 » Sat Jan 12, 2019 9:50 pm
i had so much track we had to do it. next track will be wood short track looking forward to it.
olddude13
Postby TuscoTodd » Sun Jan 13, 2019 8:54 am
Looks like a fun layout and having drift aprons, etc makes for a lot more fun! :)
Great to see your son was involved in the build as well!
:banana-dance:
Postby olddude13 » Sun Jan 20, 2019 8:42 pm
Making progress, built one more rail in turn 7 also got carried away with the foam spray
built the mound for the Champion Bridge also built the controller pits and car stations on edge of facia almost for got the catch fence is up but not complete needs posts. That piece of foam is a cutoff in turn 7
olddude13
Postby chappyman66 » Sun Jan 20, 2019 10:49 pm
Interested to watch the foam. I knew a guy who did most of his scenery that way....spray foam and caulk. Claimed it was faster and easier on the cars......
I was thinking of doing the same thing so this is helpful!
Postby 3nickel » Mon Jan 21, 2019 8:05 am
This is what I have to do to get off the floor. Thanks for the great pics olddude13. I bet that foam will look good with paint. The plaster cloth looks great. Was it time consuming to work with?
3nickel
Postby olddude13 » Mon Jan 21, 2019 8:22 am
Thanks, i may still cover foam with plaster cloth in some spots i filled the large voids with scrap packing foam then sprayed around take your time if it gets on the track it comes off after cured do not mess with it wet let it cure, Foam cures pretty fast depends on temp mine cured in a few hours you can save your cutoffs and put under your plaster cloth for hills and such
olddude13
Postby indybob009 » Fri Feb 15, 2019 1:07 pm
Nice idea using foam. Good work ' any more progress.
indybob009
Postby Fathead59 » Sun Mar 03, 2019 2:13 pm
Very nice work , thinking about doing just about the same thing, I have a Scaletrix track set that will run 6 cars wirelessly . will be using 1/4 inch foam board as boarder, keeping a little room for movement of the track when the cars are running
Fathead59
