Cheap computer for timing
Plastic Or Wood
All Things Track Building!
Re: Cheap computer for timing
Postby HomeRacingWorld » Wed Mar 01, 2017 7:22 pm
Yes sir, the days of spending a lot on a timing computer are long past. I think sharing this type of resource important for those looking to start new that have no older systems laying about.
Congratulations on your new system.
Postby BARC 1 » Wed Mar 01, 2017 7:36 pm
Guys who are running Carrera digital should be looking at this. A computer like this and Bruce's shareware will look after all your timing and fueling needs for running digital. Forget the drivers stations and buy a computer like this.
Good info right here.
Postby SpeedyNH » Fri Mar 03, 2017 6:12 pm
I've had some luck with bad HDDs. buy a new one, put the old one in the freezer and then sometimes it will work enough to get what you want off it. just did this the other day, as a matter of fact. or you can also clone it with an external cable and drive case. failing that, you can always download all the drivers for a new drive in the old machine. it just depends on how much you like the old one, or the files that were on it
I use a thing called keyfinder to copy out all my software keys in case a thing like this happens so the apps can be reactivated without having to pay for them again. (and I detest windows 10.)
speedy
SpeedyNH
Postby Z-carfan » Fri Mar 03, 2017 6:56 pm
Great deal Shotgun, You could not buy Windows 10 for that price!!
