by dreinecke » Sat Jun 07, 2014 7:46 am
Just a quick update: NOTHING is touching this stuff. Not Goof-Off, Goo-Gone, spirits, WD, nada worked. I used Venture tape and I think there is gorilla snot somewhere in the ingredients.
I used a sharp putty knife to scrape as much off as I could without damaging the surface of the track and then hit it with 120 grit on the orbital sander. Still a light line of it, but after talking to Harry, I simply tested both paint and tape over it. Not a problem with the adhesion of either and you can't tell that I wasn't using fresh MDF.
So, I'll start re-assembling this week and I'll start painting right after that.
Thanks for the ideas and suggestions though.
