[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 678: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
Home Racing World • View topic - Ideas wanted for new routed ninco digital track
Got Wood?
Your ROUTED TRACK Home!
Postby regalman82 » Fri Dec 28, 2012 12:45 pm
Santa (other half) was good to me for Christmas :mrgreen: . Got a new router and home depot gift card. Now the fun begins, as this will be my first routed track i want some input from the brotherhood of slotcar guys. I want to keep the n-digital aspect, dont know if i can take out the flipper and circuit board or just drop in the track piece. I would like to make the change overs longer so that they can be taken with speed. So here is my first design. what do you think , what would you change?
I forgot to say this is a 15'*8' area with 3 sides against the walls
Thanks for the input
Blake
regalman82
Re: Ideas wanted for new routed ninco digtial track
Postby Dangermouse » Fri Dec 28, 2012 5:21 pm
Hi Blake
lots of up and back straights with 180 turns so it will be quick but probably not very challenging.
I am learning about these as I plan my third track my thread (viewtopic.php?f=22&t=1443 ) My second track was a variation of Paramount Raceway and while fun to drive with some cars it was very predictable.
I enjoyed looking at these slot mod tracks some interesting variations in the turns an designs may give you some ideas.
Slag Raceway
Gussack Park
I like this turn
Lots more slotmods track photos - http://www.flickr.com/photos/slot_mods_usa/
and their Youtube site
I also started this discussion on another forum about the type of corners to build - routed track allows you to get away from turns that look like set track - there are some good replies in there
http://www.auslot.com/forums/index.php? ... ted-track/
cheers
David
Dangermouse
Postby regalman82 » Fri Dec 28, 2012 7:27 pm
Some great links there David thank you. Below are the last 2 plastic tracks ive had upImageImage
Both had the same outer section but different infields and the second is run in the opposite direction. I tried to not have the same curve sections with varying radius pieces
The back half needs to be a easier part to drive due reach problems. Not to mention needs to easy enough that the other half will run sometime.
Blake
regalman82
Postby regalman82 » Fri Dec 28, 2012 10:58 pm
Here is a design loosely based on the slag raceway by slotmods , reworked to meet my space. What do you think? the corners wont be constant like in the drawing sorry ninco software wont draw varying corners. :mad: Image
I really like this design seems like good flow and speed with some harder sections.
Blake
regalman82
Re: Ideas wanted for new routed ninco digital track
Postby Dangermouse » Sat Dec 29, 2012 7:26 am
Looks good Blake
Maybe you can do something else with the space in the top left section - I think you said have limited access there but it would lend itselfto trying something different for that turn leading onto the straight maybe a big S through there
cheers
David
Dangermouse
Postby regalman82 » Sat Dec 29, 2012 10:03 am
Thanks David just what i needed. Like you i love my model trains also so this will be a visual track as well a racer. I have made some changes to the overall design, here is the latest revision.
Only thing is this is my first routed track, i hope i have not biting off more than i can chew here.
Blake
regalman82
Postby Dangermouse » Sat Dec 29, 2012 11:14 am
Looks good
will be an interesting project
David
Dangermouse
Postby Scatman1 » Sat Dec 29, 2012 11:36 am
Have no fear Blake, I'm only 20 mins away. I like the last two and with some elevation chagnes and some squeezes, should be fun.
Scatman1
Postby Dangermouse » Sun Dec 30, 2012 6:43 pm
Blake
a chap on Slotforum has started a thread on making a routed track - Jens does beautiful scenery I posted a link to his track in my thread - here is a link to his new thread http://www.slotforum.com/forums/index.p ... ntry756540
cheers
David
Dangermouse
Postby regalman82 » Sat Jan 05, 2013 12:39 pm
Thanks David and Tony for all of your help and inspiration. This is going to be a fun build.
Thanks again guys.
Thank you tony for having me over friday for some routed oval running, that was great
Blake
regalman82
Return to The Lumber Yard
Users browsing this forum: No registered users and 85 guests
