sanding track after final coat of paint
Got Wood?
Your ROUTED TRACK Home!
Postby deslot » Wed Dec 02, 2015 6:12 pm
hello, im about to put down my third coat of paint on my track. I have painted and sanded after 2 coats, using a foam roller. I have noticed after sanding with 220 paper that the track felt nice and smooth, took away the orange peel.NOT really worried about the look of the track as im going to weather it. so does having a nice smooth finish have advantages over not sanding. Going to be running rubber and urethanes. :think:
deslot
Re: sanding track after final coat of paint
Postby HomeRacingWorld » Wed Dec 02, 2015 7:26 pm
Smooth is good. More rubber meeting the road. But the best will come over time as you lay the rubber down naturally.
Postby deslot » Wed Dec 02, 2015 8:17 pm
Thank you,the more i looked at the track sanded the more i liked the look not perfect. but how many roads are,especially here in northern Indiana plus better traction. a bonus :music-rockout:
deslot
Postby deslot » Wed Dec 02, 2015 8:21 pm
What grit paper would you recommend...
deslot
Postby scatman » Wed Dec 02, 2015 8:50 pm
It will help especially if you tape your track with copper. Living in the south and the track in the garage, tape has stayed in place. My other two tracks before sanding had issues with tape coming up. Just my two cents.
scatman
Postby HomeRacingWorld » Wed Dec 02, 2015 9:11 pm
Tony is correct, it helps that as well.
I sanded mine with 1000 grit wetsanding paper.
Postby deslot » Wed Dec 02, 2015 9:31 pm
Thank you both with your info. I'm going with braid this time, as soon as i can figure out how to get the pics off my phone and on my puter , i will get some up here. Thanks again....
deslot
Postby scatman » Wed Dec 02, 2015 9:45 pm
Photobucket account will do the job. There's an app also that will upload your photos.
scatman
Return to The Lumber Yard
