by DAVE » Thu Dec 27, 2012 3:55 pm
Not sure what type of timing system you use, but most systems don't require recording section
locations between heats when running timed heats. The only time you should need to record
sections is after the last heat, and only if there is a tie. Of course, this is not the way real races
are run. They run a specific number of laps and the first car over the finish line wins. But they
don't run lane rotations, so they don't have the same problem slot racers have. I guess I would
start the cars at the start line each heat, and record the laps plus the number of sections, plus
the inches past the section line. Either the timing system will have to be set up to cut the power
when the first car completes the prescribed number of laps, or a race director will have to do
the same. The cars are rotated to the next lane and returned to the start line. The process
repeats until all the lanes have been run, then you do the math;
Assuming 10 lap heats, 10 sections, and 12 inch section lengths
Finish position for: Car 1 Car 2 Car 3 Car 4
Heat number 1 10 laps 9 laps, 8 sections, 3 inches 9 laps, 6 sections, 6 inches 8 laps, 8 sections, 4 inches
Heat number 2 9 laps, 7 sections, 3 inches 9 laps, 6 sections, 10 inches 10 laps 9 laps, 4 sections, 5 inches
Heat number 3 9 laps, 10 sections, 1 inch 10 laps 9 laps, 4 sections, 11 inches 9 laps, 7 sections, 3 inches
Heat number 4 10 laps 8 laps, 9 sections, 4 inches 9 laps, 8 sections, 6 inches 10 laps
Total laps 39 laps, 7 sections, 4 inches 38 laps, 4 sections, 5 inches 38 laps, 9 sections, 11 inches 38 laps
Finish position First Third Second Fourth
This is complicated, since the only way to get 40 laps, which should be the lap total for first place, would be to win every heat. But the
win does go to the guy with the most laps. Kinda emphasizes why slot racers run timed heats, rather than lap limits.
