Home Racing World • View topic - Colored Molotow Pens?? BEWARE!!!
Custom Paint Job Showcase
Re: Colored Molotow Pens?? BEWARE!!!
Postby Fathead59 » Mon Aug 27, 2018 10:15 pm
I mean I saw that used a plastic box and a box fan as a paint booth, would have never thought of that
Fathead59
Postby mattb » Tue Aug 28, 2018 6:52 am
Postby Fathead59 » Sat Sep 01, 2018 2:16 pm
I have a quick question, if you were to spray the car with a sealer before dipping in into the future would that help with the pens, I mean after using the pens spray it with a sealer then dip it in the future? Just trying to see if they one has tried that. Planning on buying a couple of the other colors . And want to know as much as possibly , better to ask as many questions in is forum then trying it out first to find out that it didn't work.
Fathead59
Postby Fathead59 » Sat Sep 01, 2018 2:17 pm
And I am planning on building my own paint booth also. It is better than having to keep spraying them outside
Fathead59
Postby waaytoomuchintothis » Sat Sep 01, 2018 2:56 pm
Fathead, be sure to design good lighting in your booth plans. Many a good idea for a paint booth has been made a nuisance because it was not as well lit as the builder thought. I wonder if the white styrofoam meat tray diffuser could be the walls for a booth with the actual light sources completely outside of the booth?
Postby mattb » Sat Sep 01, 2018 6:25 pm
Any type of sealer will turn Molotow gray unless it
is waterbased.
I made my spray booth (shown above) with $15 and a trip to Walmart and about 30 minutes of construction time.
Postby Fathead59 » Sat Sep 01, 2018 7:56 pm
Thank you Mattb, that was a very good idea for a paint booth, I was building plastic models in my spare time with work and just sprayed them out side, no need to now . I picked up everything I need to build my own.
Fathead59
Postby Fathead59 » Sat Sep 01, 2018 8:18 pm
Thank you Way, that was something I really didn't think about, maybe I will get one of those lights that they have for cabinets, the press on kind, cover it with plastic so it doesn't get covered with overspray
Fathead59
Postby waaytoomuchintothis » Sat Sep 01, 2018 10:24 pm
Just be sure to get incandescent lights, because fluorescents distort color. You can be very happy with a nice blue paintjob, take it out and presto! Magic! Its dirty green. Oops.
Postby Fathead59 » Sun Sep 02, 2018 2:36 am
Do you brush on that type of sealer or do you spray it on , I have been looking on getting a air spraying set up with a small air compressor
Fathead59
Postby mattb » Sun Sep 02, 2018 7:04 am
You can brush the Pledge/Future with good results. Just put it on thick and let it flow out.
Return to The Paint Booth
Users browsing this forum: No registered users and 33 guests
