after consulting with HRW members that have done this ,i thought i would give it a try. I am not good at picture taking,and the camera i just got is not cooperating,so ill do the best i can. this may take a few days as i have not received the SRP bodies ordered yet,will probably be Thurs, or Friday. Getting started on the parts list first and some pictures of the basic chassis arrangement. I will be assuming that since this is posted in the scratch builders section that everyone knows how to solder,and has most of the tools needed to do a build like this. pretty straight forward build and very easy and fast.
i am in the process of finishing the last two for my 6 lane field of this style midgets,If anyone is planning on more than one build,a quick pin jig would be faster yet,but not needed as i stated earlier,they are very a straight forward build.
I have stated before how much fun these are,and they are very easy to get tuned for the track,so far the only tweaking needed after the initial build was to spread the brushes a little to make good contact through the corners,and a little truing of the tires. So with that being said,this is what we will be building.
