I got a bit more done, I took bushings from an old carrera 1\32 axle and reamed them out to .125 and adding more brass rod I got the rear
bushings on the frame
The floor pan is .062 X 1.0 inch brass strip from K&S I had to cut the width down to .875 I used an X-Acto razor saw, it cut good and gave me a nice little strip for other stuff
I drilled out the motor mounts and bent with my pliers
I need to put on some body parts to see how to get the guide keel under it but its just about ready.
This was a lot easier than I thought, the tools I used are what most of us have in our box, give it a try :banana-rock:
