Skinny wheels
Skinny wheels
Postby noddaz » Fri Mar 29, 2019 6:22 pm
I am working on a Hot Rod type build and need some skinny wheels and tires for the front. I am currently using a pair of wheels I stole from Doc Hudson, but I don't think that these will actually stay on the car if I race it.
So I am looking for some narrow "steelies" to run on the front and something a bit wider to run on the rear.
Anyone?
Scott
noddaz
Re: Skinny wheels
Postby chrisguyw » Fri Mar 29, 2019 8:31 pm
SCC has some quite nice wheels in 14 and 15mm diameters in both "Steelie" and "insert" varieties,..... their narrowest is 6mm.
RSslotracing has some 15 x 5mm insert wheels and "Steel" inserts that would look good on the front, and some 15 x 7mm insert wheels (and steel insets) for the rear.
Chris Walker
chrisguyw
Re: Skinny wheels
Postby Mitch58 » Sat Mar 30, 2019 10:01 am
You can get 15x7 wheels in various styles from CB Design.
I believe that Pendles has 15x6 wheels with a 2mm rib.
Mitch58
Users browsing this forum: No registered users and 107 guests
