Home Racing World • View topic - NEW motor mount/bracket for scratching??
Postby Broman62 » Sat Dec 09, 2017 2:11 pm
Re: NEW motor mount/bracket for scratching??
Postby HomeRacingWorld » Sat Dec 09, 2017 3:19 pm
Yes sir thanks for sharing this. Very handy bracket.
Postby waaytoomuchintothis » Sat Dec 09, 2017 3:24 pm
Yep, the forged version (squared off, rabbited bottom edge for soldering), is also more fragile than this one. I broke one of the forged ones in half once, but these sheet metal brass ones are tough. Both have had the offset for many years.
Postby TuscoTodd » Sat Dec 09, 2017 5:33 pm
Good info and great detail / pics! Thank you for sharing!
Postby Ky.Slot Racer » Sun Dec 10, 2017 7:18 am
does either of the the other 2 holes line up for a 050 can motor to screw onto?
Ky.Slot Racer
HRW Master Modeler
Postby Broman62 » Sun Dec 10, 2017 8:41 am
Postby Ky.Slot Racer » Sun Dec 10, 2017 8:45 am
perfect, exactly what I was wanting to know thank you
Ky.Slot Racer
HRW Master Modeler
Postby Ky.Slot Racer » Sun Dec 10, 2017 11:34 am
confused now, part# PMTR5012 shows only 2 motor mounting holes does it in fact come with 4?
Ky.Slot Racer
HRW Master Modeler
Postby Broman62 » Sun Dec 10, 2017 7:42 pm
Mark, that is the exact one I bought...had to go back to his site and check and check my invoice and that’s what I received with 4 holes.
Postby Ky.Slot Racer » Sun Dec 10, 2017 11:08 pm
Copy that, thanks again for the clarification :text-thankyouyellow:
Ky.Slot Racer
HRW Master Modeler
Postby munter » Mon Dec 11, 2017 1:09 am
I have these for the ff motors. One is like the old BWA bracket ie short and the other is slightly longer with a 1mm offset.
After getting a bunch made I sold a lot to a dealer in the UK and then more to a guy in Aussie.
They are made of panel steel which solders well, not as nice as brass but there was an issue with the laser cutter.
There are few left in my stash before I re order....$US3.50 per piece
The holes are for a 3/16 oilite and an M2 motor screw both of which I can supply for a bit more.
Postby bill from nh » Wed Dec 27, 2017 7:10 pm
If my memory is still any good, the vertical mounting holes in the PM bracket were for mounting 16D-type motors. I got some of these brackets about 10 yrs. ago, but had thought PM sold out & wasn't going to carry them since they also had the cast brass brackets. It's nice to see they're still available, since they're strong & cheap.
PM also sold a matching droparm to these brackets. It'll be interesting if they're still available.I didn't find the droparms listed on the PM site, so one will will have to make their own using one of the various construction methods when needed.
bill from nh
