1966 Eldon Ferrari p3 Finished!
Postby btaylor » Fri Aug 11, 2017 4:43 am
I have had a few of these bodies around for a while now. I wanted to build an early (66) P3 that didn't have the shark vents behind the rear wheels. I think this Eldon body can be made to look the part pretty well. It will be red of course, and plans call for full lighting and clear glass (vac formed from the original smoke version). So far it is a parts box build, and actually runs quite well. The chassis is my old stand by Artin, cut down to fit the body. Wheels are Cartrix BMW. They look pretty close to the thick 5 spoke wheels on the 1:1 car. they will be gold centered. axles are slot it,motor is a Ninco I believe, it checked at around 17,00 rpm, and runs close times to my others in this series. Tires for now are a mix of silicone fronts, and rubber Monogram rear. I will be replacing them with PG tires. Its already a fun car to run, so it should be a nice addition when finished.
Dire straights raceway / SSD roadcourse
Cherokee Point 80' Road course
Re: 1966 Eldon Ferrari p3
Postby HomeRacingWorld » Fri Aug 11, 2017 5:30 am
That's a good one there Bob. Good old Artin chassis to the rescue again eh?
"They didn't say you couldn't" - Smokey
Postby BARC 1 » Fri Aug 11, 2017 5:39 am
Nice to see the old classics getting a revamp
Looks like you have an old Porsche to do as well
Postby btaylor » Fri Aug 11, 2017 6:00 am
HomeRacingWorld wrote:That's a good one there Bob. Good old Artin chassis to the rescue again eh?
Yes Sir! Simple and effective. Cant get enough of them. And yes Barc, I have a few more Strommies and Eldon bodies that need built. winters coming!
Postby Mitch58 » Fri Aug 11, 2017 8:36 am
I'll be watching, as I have the same body and was wondering what to do with it. I've already completed the Eldon 906. BTW the 3D printed universal chassis fits the existing mounts on most Eldon, Monogram, and Revell bodies without modification.
Mitch58
Postby ourwayband » Fri Aug 11, 2017 11:34 am
Love seeing this..Always had a soft spot for the Eldon range.Those would have been my slot cars if I had had a set in the 60's/70's...We put some Eldon bodies on some black widow Scaley NASCARS chassis several years back when those were cheap and easy to find....
Re: 1966 Eldon Ferrari p3 Finished!
Postby btaylor » Sat Aug 12, 2017 5:16 am
Waiting on some clear sheets to vac form the new glass, but its done, and a runner. lights work great, and the car fits right in with my Others.
Postby Audi1 » Sun Aug 13, 2017 5:16 am
Nice job, Bob! Looks like a smooth runner.
Postby TuscoTodd » Sun Aug 13, 2017 5:37 am
That turned out sharp!
:text-bravo:
Postby 2FER SLOTS » Sun Aug 13, 2017 8:18 am
Nice job !
You just inspired my to get back to work on slot car projects, thanks. ;)
Pax Domini
2FER SLOTS
Postby dge467 » Sun Aug 13, 2017 8:18 am
Looks great Bob!
