1/32 Opel GT Update, Finished!
Postby dge467 » Fri Jun 23, 2017 6:07 pm
I am building this using the reissued Revell kit. The chassis is a pretty hacked up Scalextric 69 Camaro piece that has been in my junk box. I added some Plastruct "L" channel to strengthen the chassis and to the rear of the chassis also for the mounting screws. Front axle has been relocated to match the wheel base. I am also using the 69 Camaro interior too, also from the junk box! The Opel dashboard will be used though. Check in for more updates.
Re: 1/32 Opel GT
Postby HomeRacingWorld » Fri Jun 23, 2017 6:08 pm
Will check in. Nice choice.
Re: 1/32 Opel GT
Postby TuscoTodd » Sat Jun 24, 2017 6:30 am
This looks like it is going to be a cool build!
Looking forward to seeing the updates! :)
Re: 1/32 Opel GT
Postby dge467 » Sun Jun 25, 2017 9:27 pm
Thanks for looking! I got the body painted with Tamiya Camel Yellow and clear coated.
The interior is almost finished. I had no roll bars that fit in my spares box, so I made one out of some brass rod.
Re: 1/32 Opel GT Update 6/25
Postby vins123 » Sun Jun 25, 2017 9:40 pm
HI Jeff
really nice work
Sylvain
vins123
Postby dge467 » Mon Jun 26, 2017 7:36 pm
Thanks Sylvain! How are you doing?
Postby Dundee Denny » Tue Jun 27, 2017 7:24 pm
One of my favorites, look forward to see it all decked out and on the track!!!
Dundee Denny
Dundee Denny
Postby dge467 » Fri Jun 30, 2017 5:36 pm
Not sure when I will update, as Photobucket has deleted third party images and I deleted my account and pic's.
Postby SpeedyNH » Sat Jul 01, 2017 6:56 pm
good idea.
SpeedyNH
Postby dge467 » Sun Jul 02, 2017 8:43 pm
Pic's back up! Thanks Harry! Updates real soon.
Postby dge467 » Wed Jul 05, 2017 9:11 pm
Well it is finally done!! Well almost, I am just waiting for the pinion gear to install on the H&R Jack Rabbit motor.I am using the Scalextric motor till then. I painted the wheels flat white and installed a pair of PG tires on the rear. The side pipes are from the junk box and painted flat white too. The trim and bumpers are done with chrome foil as usual. I added the assortment of decals and put a coat of Future floor wax over them. I imagine a small V-8 stuffed under the hood!
Re: 1/32 Opel GT Update, Finished!
Postby TuscoTodd » Thu Jul 06, 2017 8:41 am
That turned out SHARP!!!
Bravo sir!
Postby valie » Thu Jul 06, 2017 9:39 am
Well, in Opel competition yellow, a set of minilites and two side pipes! There's no 1900cc four pots in there anymore, no sir!
Darn good job! I like it!
valie
Postby chappyman66 » Thu Jul 06, 2017 12:59 pm
Oh yeah, that is a lovely little car! Nice job, hopefully it runs well?
Postby dge467 » Thu Jul 06, 2017 6:28 pm
Thanks all! Chappyman66, it runs and handles great!!! The Scaley motor is a bit much though. I will be installing the Jack Rabbit motor tonight hopefully!
Users browsing this forum: No registered users and 34 guests
