Home Racing World • View topic - Scaleauto guide options
Postby HomeRacingWorld » Tue Jan 23, 2018 3:50 pm
Re: Scaleauto guide options
Postby munter » Wed Jan 24, 2018 3:43 am
They are good alright but what I cannot figure out is the two options of the stem diameter?
Postby mikeinclover » Wed Jan 24, 2018 6:24 am
mikeinclover
Postby munter » Wed Jan 24, 2018 10:02 pm
Thanks Mike
I can see the difference now you mention it.
I also realise I am confused about the actual guides.
There are other SC guides in red, right?
Postby HomeRacingWorld » Wed Jan 24, 2018 11:25 pm
Postby munter » Thu Jan 25, 2018 2:47 am
Thanks Harry, they were what I thought I was commenting on previously.
They perform well and are economical compared to some brands.
Postby mikeinclover » Thu Jan 25, 2018 7:07 am
Munter, basically the SC-1603, 1604, 1607 and 1608 are all 1/32 guides and the rest are for 1/24 car's. The 1/24th take a nut instead of a screw and the braid they use is the bigger type. I am sure you could use standard braid.
Mike
mikeinclover
Postby gascarnut » Thu Jan 25, 2018 10:30 am
To use the "standard" 1/32 type braid, you would need to crimp a length of it into the brass guide clips that are used for the thicker, heavier 1/24 braid. I've done this quite often and it works fine. You need to have a pair of the bigger braids, though. Pull the heavy braid out of the clip by holding the braid in a pair of pliers and tugging - it will slide out. Then feed the thinner braid into the clip and squash the clip down to hold it in place.
The best nuts to use for holding these guides onto the chassis are these:
https://www.slotcarcorner.com/1-24-Slot ... p2688.html
Or these:
https://www.slotcarcorner.com/1-24-Slot ... p2689.html
They do require a special tool, but then who doesn't like extra tools?
https://www.slotcarcorner.com/Samson-Cl ... p2687.html
gascarnut
