Home Racing World • View topic - Policar compatible chassis - Fly Williams FW08C
Postby Conti_rowland » Thu Jun 23, 2016 6:37 am
Conti_rowland
Re: Policar compatible chassis - Fly Williams FW08C
Postby Conti_rowland » Sun Jul 24, 2016 12:56 am
Conti_rowland
Postby chappy » Sun Jul 24, 2016 6:23 am
Thanks Andi, now if only our Driver could lose a pound or two lol
Excellent tutorial, again.
Postby Abarth Mike » Sun Jul 24, 2016 8:46 pm
Andi,
:?: Do you know the overall width of the policar motor/axle mount unit. I need a very narrow one for a project I have in mind. Penelope Pitlane SM1m is the narrowest I've found so far.
Mike
Abarth Mike
Postby Conti_rowland » Sun Jul 24, 2016 10:16 pm
Thanks guys
Its 17mm wide Mike if you cut off the water pipes. With some more careful material removal you can get it to 16mm without affecting anything structural.
How does that sound?
Bob, I did consider doing an added tutorial on lowering the driver but decided that was beyond the scope of the How-to......
Andi
Conti_rowland
Postby Abarth Mike » Mon Jul 25, 2016 12:22 am
Thank you Andi. 16mm will work. I've managed to get a Scalex A1 chassis down to 16mm by gluing an extra bushing section in and then cutting one old one off :o
But i have had difficulty finding a narrow pinion to fit between the bushings and still align the gear mesh. Which is why the Policar looks interesting. I will have to dig all my previous work out and have a look.
If I may? later I'll send you a PM. If only to maybe rekindle my project enthusiasm. Either on here or another place ;)
Abarth Mike
Users browsing this forum: No registered users and 44 guests
