Home Racing World • View topic - Carrera Ford GT
Page 2 of 2
Re: Carrera Ford GT
PostPosted: Thu Aug 17, 2017 7:30 am
by Drewbert34
Re: Carrera Ford GT
PostPosted: Thu Aug 17, 2017 12:52 pm
I had considered a similar modification, but that would not be legal under our rules. If the front end was lowered by that method the guide flag would still hold up the front of the car.
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 5:58 am
by grenou2009
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 6:15 am
How many miles does that older one have on it? There is a lot to be said for good break in time.
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 6:34 am
by grenou2009
Not knowing how many milles travelled but checking in my Quicken accounts, I bought the CR6 in sept. 2014, then the CR7 in aug. 2015 and the CR8 jan. 2017. Like you mentioned, for sure that CR6 ran much more than the other 2;
p.s. my old black BMW M3 DTM car beets all of my 1/32's and that one was bought in july 2014, so I guess my 2014 cars are running pretty good ;)
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 6:43 am
Well yes, we don't know how many miles. I worded that wrong.
Some of the fastest Carrera are my older C6's. lots of time in them and those motors are well broken in.
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 9:31 am
by Drewbert34
To add color to the motor break in discussion. I have a stock Carrera E200 in my Farfus DTM that will match a Pirhana motored similarly equipped DTM. Granted, that's an exception vs. the rule, but that Farfus car was my very 1st DTM car with more laps than I could even guess.
Re: Carrera Ford GT
PostPosted: Fri Aug 18, 2017 12:30 pm
by grenou2009
Re: Carrera Ford GT
PostPosted: Sat Aug 19, 2017 8:06 am
There are a couple of things that might cause the Ford GT to be a little slower. For one thing the car has a lot of ground clearance, so even though the body looks lower the actual CG might be about the same. The car is also on the heavy side, in order to reproduce the flying buttresses the body has two parts and that adds weight higher up. In my case I am running on wood tracks, one of our tracks does have Magnabraid, but we run without traction magnets in any case. If you do run with traction magnets consider that with the Ford GT the magnets would be further away from the rails.
When you tune cars to run without magnets little things can have a big impact on how the car will handle. The cars will benefit from having some body float, without it the cars tend to chatter when you accelerate out of a turn. Too much body float can cause the handling to become erratic.
Another issue to consider is the motors. There is a fair variation in the performance of the motors. I don't have a 1/32nd track, when I get a new motor I run it in on the bench for 30 minutes at 6 volts. I flush the commutator with contact cleaner and oil the bearings before I check the RPMs with a non-contact tachometer. The motors that I have tested range from 16 to 20K RPM. The Ford GT that I have came with a 17K motor, I switched to a 19K motor. RPM readings by themselves do not tell the whole story, but the can separate the dogs from the possible winners.
The tires that come with the cars are not necessarily all the same, the tires that came with the two Corvette C7Rs that I bought were harder than the ones On the Ford GT. The tires will benefit from being trued, but I found that the softer tires were difficult to true.
Re: Carrera Ford GT
PostPosted: Fri Aug 25, 2017 7:11 pm
by grenou2009
