Home Racing World • View topic - Racer Sideways Porsche Kremer 935K2
Share Your Thoughts!
Postby HomeRacingWorld » Wed Aug 19, 2015 7:56 pm
Re: Racer Sideways Porsche Kremer 935K2
Postby chappy » Wed Aug 19, 2015 10:17 pm
Nice review Harry, ireally like the livery too.
I think my favorite thing about the Racer Sideways Grp 5 cars, is this.
Since the first one hit the market , right up to current, Sideways has maintained the same technologies on each car ensuring a competitive field.
For our club it means we can buy the new releases and not have to worry if they are better than the previous releases.
This is a real plus in my books , that a lot of other manufacturers should take note of.
Keep the series the same in motors and chassis tech so they can remain competitive with each other.
A big thing in my purchases.
And yes Slot it are much the same since any new developments most often include the spares to upgrade the older models for a very modest price.
Of course that is just one mans opinion.
The General, has great taste by the way.
Postby HomeRacingWorld » Wed Aug 19, 2015 11:50 pm
Thanks guys.
Well Bob...it's a big deal. You are your club are just a few of many who feel the same way. I do as well.
Postby HRWJim » Thu Aug 20, 2015 8:33 am
I will throw my two cents in that these are great cars. I have done the motor change and they are perfect for a small track. I am a big fan of group 5 and just might have to pick this one up. Jim
Postby HomeRacingWorld » Sat Aug 22, 2015 8:34 pm
Decided to have some fun this evening and tune this car to match the rest.
I did try the "Hard as nails" adhesive Paul talked about. I went over to "that area" in Wal-Mart and found it quickly, and left.
It goes on nicely and I let it sit about 1/2 hour.
Razor time. I use 1500 grit and took my time.
Remember that if you use a slightly larger tire, you will need to sand the inner sidewalls a little. These anglewinders don't give you much room so in order to fit a little more meat underneath, you sometimes have to massage things.
MT5 is our motor of choice for these car on our track. Everything else but the PG tires is stock.
I mount the motor using the lowest setting to make sure it clears the interior and to get it as low as possible for balance.
Not bad times: 3.82 average after a few 25 lap heats. That is very consistent with others in the class around here.
Fun time with this car this evening. Runs like you would expect.
Postby noddaz » Sun Aug 30, 2015 6:38 pm
And just where was the "Hard as Nails" used on the car?
Front tires?
Just wondering..
Scott
noddaz
Postby HomeRacingWorld » Sun Aug 30, 2015 7:16 pm
Postby chappy » Sun Aug 30, 2015 8:46 pm
Great tip on the tire adhesive Harry, I never even thought of it.
Tomorrow , I will go, to, the post office which happens to be at the back of the pharmacy lol.
So the hard as nails is better than just nail polish ?
Postby noddaz » Mon Aug 31, 2015 5:36 am
Ahh HA. Very good. Thank you for that tip.
Scott
noddaz
Postby HomeRacingWorld » Mon Aug 31, 2015 6:24 am
You are welcome.
It seems a little tougher/stronger than regular polish Bob.
Postby loosewheel » Mon Aug 31, 2015 8:16 am
How easy is it to remove the tires after using it?
loosewheel
Postby HomeRacingWorld » Mon Aug 31, 2015 8:42 am
Easy as in can you remove them without damaging the tire? You can, but likely the insides will tear, leaving some urethane/adhesive on the wheel you must clean off.
But when I mount them, they are on there until they wear out. Which takes quite awhile. So tearing a worn out tire does not concern me.
Removing the tire is easy enough to me, but you will need to pull on them with a little force as this product does what you want it to do.
Remember, you don't HAVE to glue them. Some racers do and some don't. I find gluing reduces the expansion and helps prevent the tire from excess roll in the corners.
Postby buspor63 » Tue Sep 01, 2015 2:21 am
Is the SH nail polish safe for plastic wheels, or is it to "hot"?
buspor63
Postby HomeRacingWorld » Tue Sep 01, 2015 8:13 am
I tested it only by brushing it on some Ninco and Pioneer wheels. Did not eat/melt them. I don't normally glue to plastic so I just tested it on aluminum wheels.
Postby Slot_It_bob » Fri Oct 16, 2015 10:45 am
Will the SH Hard as Nails work with Silicone tires just as well?
Slot_It_bob
Return to Product Reviews!
