by dr fabio » Fri Mar 06, 2015 2:33 am
I think the Mustang is a better car. The front sits proud with the guide not fully in the slot. Buff down the tyres to reduce the diameter by about 2mm. Replace the front bearings with some old scaly ones as the Pioneer bearings are too sloppy for non mag racing. This will drop the height of the car. This will also allow you to run up to 4mm wider front track. With some careful rear wheel arch sanding you can squeeze between 2-4mm extra rear wheel track. Usually body float stuff also remove the locating tabs on the bottom of the interior as you cant get float with them in place. Run 13T pinion and 36T spur on short tracks. Long tracks with straights in excess of 10 metres use 34T spur.
