Home Racing World • View topic - AFX should do some drag cars. Thoughts?
Vintage to Modern
Re: AFX should do some drag cars. Thoughts?
Postby aviva7 » Mon Dec 31, 2018 3:17 pm
In what ways is it more tunable, beyond those three axles holes (The AW Super III has as many, if not more)?
aviva7
Postby downtowndeco » Mon Dec 31, 2018 4:57 pm
I have a JAG DR-1 but have not played with it yet. The problem seems to be that it will also take some extra work to narrow up to tuck under available bodies. Thoughts?
downtowndeco
Postby aviva7 » Mon Dec 31, 2018 5:19 pm
That the best chassis for 'tucking under' is the HighWingPilot SL2.
aviva7
Postby downtowndeco » Mon Dec 31, 2018 5:36 pm
It looks like it would work fine, except then you have to buy a motor, pickups, guide, wheels, tires etc. I can already kitbash/fabricate/adapt something if I wanted to. Thanks though, peace.
downtowndeco
Postby aviva7 » Mon Dec 31, 2018 5:41 pm
It is the only chassis narrow enough for many of the things I see people wishing for.
Only you can decide if building one is worth it to have the latest of yours granted.
aviva7
Postby model murdering » Tue Jan 01, 2019 1:52 am
JAG DR-1 "Narrow"
model murdering
Postby downtowndeco » Tue Jan 01, 2019 10:00 am
That looks like exactly what I'm looking for. How does it look w/an AW Funny Car body on it?
Now that I look at it this is the chassis I already have sitting in a box. They don't make a "narrow" DR-1, do they? Just different wheel color variations I think.
downtowndeco
Postby nhdungeonracer » Tue Jan 01, 2019 10:55 am
Postby model murdering » Tue Jan 01, 2019 11:20 am
Hi Deco, bear with me here.
Close one eye and squint through your good one, hang yer tongue out a bit, looking over the top of your thumb, so as to super impose the two DR-1 chassis pictures. Put the narrower taller appearing rims from the standard DR-1 on the DR-1 "Narrow". The disclaimer would be if the trac width put your skins on the rails, but I seriously doubt that would be the case.
Would that get you going in the tight direction ?
Good luck!
Bill
model murdering
Postby bookie » Tue Jan 01, 2019 11:24 am
bookie
Postby downtowndeco » Tue Jan 01, 2019 12:56 pm
Thanks to all for this discussion. In the end, the simplest solution to what I want to get is to just did what Sweet did, use 4 Gear chassis & cut down the hubs.
downtowndeco
Return to Holeshot Alley!
Users browsing this forum: No registered users and 49 guests
