Home Racing World • View topic - Southern Thunder raceway under construction!
Vintage to Modern
Re: Southern Thunder raceway under construction!
Postby btaylor » Sat Mar 25, 2017 1:56 pm
To answer your question Dave, Yes, I used particle board. 5/8" to be exact. since I was going in a straight line, it didn't matter much, and was a lot cheaper than MDF. The router still burns/melts the bonding agent and seals the groove pretty good.
Now for the good stuff! I made some progress on the strip today. I have even made test runs on both lanes.
I can only say, that having that much fun with only the first section done, tells me I'm in for a good time at 48' ! Here's what I have done so far. The drivers stations are wired, and waiting on controller holders. I used a trick I saw on You tube, where a guy used romex wire to make the loops that hook up the controllers. its a neat idea, and is cheap also. two holes for each clip, and you run the wire back through and bend it over.
I also got the side rails up, and routed a center divider to keep the launching cars apart.
I am using a PM 15 amp power supply, and PM controllers for now.
Still a good ways to go, but its coming together nicely enough that I am happy with it.
Hope ya'all like it!
Postby btaylor » Sun Mar 26, 2017 5:03 am
I have been working on the first section quite a bit. I am waiting on my steel tubing, so I got into the details a little. :oops: My daughter has a machine that cuts vinyl, so I put her to work on these track signs. I think they came out rather good! The lane divider was kinda boring, so it woke it up a little.
Postby Racie35 » Sun Mar 26, 2017 6:25 am
I'd like to be track champ...when's the first race.
Racie35
Postby btaylor » Mon Mar 27, 2017 4:22 am
Postby HomeRacingWorld » Mon Mar 27, 2017 7:00 am
Looking good Bob, this will be one fun track.
Postby btaylor » Tue Mar 28, 2017 5:05 am
Sometimes things just go right, and it all comes together. Been lucky i guess? Just like the oval though, i cant stay away from running the cars.
Postby GASSERMAN » Fri Apr 07, 2017 6:45 pm
Bob your Drag Strip looks really nice . I didn't know you built that. Just came across it now. How long is it ? Where do you have it set up at ? Thanks . Bob....................................
GASSERMAN
Postby BARC 1 » Fri Apr 07, 2017 8:44 pm
I have never seen a slot drag track in action. What stops the cars at the end.?
Postby btaylor » Sat Apr 08, 2017 9:24 am
Postby GASSERMAN » Sat Apr 08, 2017 1:20 pm
That's really neat Bob. I was going to build one about 3 years ago. But never did. I did build a lot of 1/24 Drag cars. And I did end up selling all on Ebay. I wish I could post pictures on here. I could show them all to you. Keep us updated Bob.. Bob.....................
GASSERMAN
Postby Ecbill » Thu May 04, 2017 4:18 pm
What scale is this track?
Ecbill
Postby seal666 » Thu May 04, 2017 6:29 pm
Bob, great work as usual, just one question, have you figured out a working drag chute?
seal666
Postby btaylor » Fri May 05, 2017 4:29 am
Postby historiceng » Thu Feb 21, 2019 4:33 pm
Bob,
Sorry to drag (sorry for pun) this one back out of the archives, but do you still have this dragstrip track?
historiceng
Return to Holeshot Alley!
