by RichD » Sun Nov 04, 2012 8:33 am
Womp cars have 1/8th inch axles and the wheels and tires are really not 1/32nd scale. Your best bet is probably to coat the tires that came with the car with black silicone sealent. If you want to use regular 1/32nd silicone tires you will have to change to a 3/32nd rear axle assembly including the bearings, axle, crown gear and wheels.
