Home Racing World • View topic - Having coffee with it - DONE!
Postby HomeRacingWorld » Sat Aug 05, 2017 6:54 am
Good old Joe! Helping figure out what I am going to do for years.
One if those projects you thought you knew what you were going to do...and then? Poof. That's ok, couple more cups and I'll get it sorted.
Posted using Tapatalk Pro
Re: Having coffee with it
Postby 4424ever » Sat Aug 05, 2017 7:08 am
I'm sure it will be another stunner interested to see the paint you decide on. By the way what motor is that?
4424ever
Postby HomeRacingWorld » Sat Aug 05, 2017 7:19 am
Postby dreinecke » Sat Aug 05, 2017 7:36 am
Either way you go, it'll be a gem. I'm enjoying mine while pouring orders this morning. Nothing like the smell of resin in the morning!
Postby HomeRacingWorld » Sat Aug 05, 2017 8:38 am
Postby HomeRacingWorld » Sat Aug 05, 2017 10:51 am
Well coffee worked ok so far.
Postby HomeRacingWorld » Sat Aug 05, 2017 1:20 pm
:banana-dance: :banana-dance:
Score one for Shotgun!
Postby HomeRacingWorld » Sat Aug 05, 2017 8:21 pm
Well, not a bad day of building.
I'm not really a wire guy, so delving into new territory. Not an award winning effort buy a long shot, but it's straight and true.
Fun times. Coffee isn't that bad for you after all :)
Postby dreinecke » Sat Aug 05, 2017 8:31 pm
That is super clean! Nice design too.
Postby HRWJim » Sat Aug 05, 2017 10:15 pm
I would give it 5 stars. Great looking chassis
Postby TuscoTodd » Sun Aug 06, 2017 6:03 am
That is a sharp looking chassis sir!
:text-bravo:
Postby munter » Sun Aug 06, 2017 1:42 pm
Nice job....wire can give a chassis a certain dynamic (torsional rigidity) that brass rod/tube doesn't.
I usually have a main rail in wire and then add some brass rod as desired.
I am sure that chassis will handle well.
munter
Postby bill from nh » Sun Aug 06, 2017 5:08 pm
The chassis looks fine, it should be another winner. If you tire of bending wire, there's no reason why you can't substitute easier worked brass rod for the wire. I can't tell the dia. of your middle spacing rail, but if it's .078 wire, you might have to use something else unless you have some 2 mm. brass rod, but any size rod will work. The brass rod will provide you with a chassis slightly heavier, but not as stiff as the piano wire, two characteristics you may of may not want, John's suggestion of using brass rod rails & one piano wire rail for strength is a good one. This rail combination has been popular on 1/24 chassis for the last 10-12 yrs. & it still works. :)
bill from nh
Postby HomeRacingWorld » Sun Aug 06, 2017 5:30 pm
Thanks guys.
The larger rail against the motor bracket was 3/32. Pretty large but I needed a little height for my mount tabs.
Out of the paint shop and ready for gear.
Postby Junior » Sun Aug 06, 2017 5:37 pm
Very nice Harry, sign me up for the chassis building seminar in Sept.
Junior
Shop Teacher
