7th Annual Michigan 24 - Slot Racers Giving Back
Re: 7th Annual Michigan 24 - Slot Racers Giving Back
Postby Quick Slicks » Tue Mar 14, 2017 8:20 pm
Slot Car Corner Canada has just donated another great prize to the Slot Racers Giving Back charity fundraising event - a Limited Edition Slot.it Audi R-18 e-tron Quattro 4WD!! Thank you Christian!
:text-thankyouyellow:
Quick Slicks
Postby cgingras » Wed Mar 15, 2017 9:03 pm
Ken Brown, from Winnipeg (Manitoba) is a great customer at Slot Car Corner Canada. Ken has decided to participate in the Slot Racers Giving Back charity fundraising by donating all its SCCC Points that he has accumulated in the last few months. Instead of using the SCCC Points to get a reward, like he was entitled to, he decided to give them back. I decided to add a little to its total and together, we're adding another nice slot car to the prize list.
The newly released Ferrari F40 LM from Policar is now another prize that you can win, thanks to Ken's generosity.
The updated prize list is here.
cgingras
Win a Difalco DD301 NEO 1/32 Controller!!
Postby SlotCarCorner » Thu Mar 16, 2017 7:30 am
Jim Difalco of Difalco Design fame has graciously donated a Difalco DD301 NEO 1/32 Controller to our Slot Racers Giving Back charity fundraising prize pool!! Jim has been hand building controllers for over 40 years - his controllers are used by slot racers the world over including many national and world champions. However, there is a caveat - we must raise at least $1,200 in donations for this prize to be given away. For those of you not familiar with the Difalco NEO 1/32 controllers, Harry did a review of the DD300 last year - here is the link. Note the DD301 has all of the same features but unlike the DD300 which has a fixed resistor network, the DD301 allows you to plug-in different resistor networks to fine-tune the controller's sensitivity. Retail value of the Difalco DD301 is $162.00 - if you've been waiting for an excuse to make a donation, what are you waiting for?
Image Image
Here is a summary of features:
Description
The Difalco Neo DD301 is a high-performance 1:32 controller with many of the same features as the high-end Difalco Genesis controllers at a lower price point.  Many of these features are not available in competitor's comparably priced controllers.
* 30 Bands:  The 30-band design provides smoother, more precise control than comparably priced controllers.
* Flexibility:  Unlike resistor based controllers which are designed to work for a very narrow range of applications, the Difalco 30-band Neo controller will work with virtually any 1/32 motor.
* Adjustable Braking:  Provides a wide range of adjustment to match car, track and driver characteristics for optimum performance.
* Adjustable Sensitivity:  Provides a wide range of adjustment to match car, track and driver characteristics for optimum performance.
* Resistor Network:  Like the high-end Genesis 1:32 controllers, the 30-band Neo DD301 controller features a small resistor network board that plugs into the main controller board.  Additional resistor network boards are available in our online store.  The additional (optional) resistor networks give you the option to further tune the performance characteristics of the 30-band Neo controller to your specific requirements.
* Ball Bearing Trigger With Threaded Trigger Pin:  Designed for heavy-duty use and long life.  The ball bearings provide silky smooth trigger action resulting in more precise control.  They will not wear like standard oilites that induce trigger side play and cause poor wiper button contact.  The adjustable pivot nut means even after years of heavy use your controller will never develop trigger "slop" like other brands.
* Dual Polarity:  The Neo DD301 is wired for positive polarity at the factory; however, this can be easily changed with a small screwdriver by the user if desired.
* Design:  All Difalco Neo controllers are built on a fiberglass frame with a large floating brass power contact (for maximum power transfer), stainless steel hardware, and heavy duty wire. The circuit board is nickel plated and will not corrode like plain copper designs.
* Ergonomics:  Difalco Neo controller feature a sturdy, comfortable Parma handle that can be used for extended periods of time without causing pain or fatique.  This is the same handle used on the higher-end Genesis controllers.
* Ease of Maintenance:  With minimal user maintenance, your Difalco Neo controller will give you many years of trouble-free service.  Clearly written maintenance instructions are included.  The open frame design makes routine cleaning and maintenance quick and easy.
* Service and Support:  Complete troubleshooting instructions are included so in the unlikely event a problem should occur racers can quickly diagnose and fix most problems with readily available, inexpensive repair parts.  No need to send your controller back to the factory or another country.  In the event you need assistance, Jim at Difalco Design will be there with his 45 years of slot racing knowledge for advice or to service your controller.
Website: www.slotcarcorner.com
Phone: 603.753.6263
Facebook: Slot Car Corner
SlotCarCorner
Postby cgingras » Thu Mar 16, 2017 4:27 pm
Tom Coulas, from Slot Car Universe, has added a nice prize to the list.
You can now win a Pioneer «Smokey Yunick» Chevy Camaro, thanks to Tom. Slot Car Universe is the distributor for Pioneer in Canada.
Don't forget to buy your raffle tickets. No tickets, no prizes!
cgingras
Postby SlotCarCorner » Fri Mar 17, 2017 6:28 am
Here's an incredible prize donated by Acme Branding Company - it's a Single-cutaway ESP LTD EC-401QMV with a quilted maple top and DiMarzio pickups. There is a caveat - we must reach $2,000 in donations to give this guitar away.
The ESP LTD EC-401QMV electric guitar features a single-cutaway vintage-thickness mahogany body with a spectacular quilted maple top for superior resonance and stunning beauty. The mahogany set neck has a thin U-shaped contour with a satin finish and 22 extra jumbo frets resulting in a perfect combination of ultra-comfortable feel, fast playability and outstanding sustain.
The black, open-coil DiMarzio 36th anniversary pickups, which possess a soft magnetic field and sweet tone, forge a perfect balance between warmth and clarity and arm this guitar with the ability to go from clean to distorted by pick attack alone. The split-coil feature on both pickups further expands the versatility of this beautiful instrument.
The ESP LTD EC-401QMV includes a push/pull tone control for splitting both pickups and is handsomely appointed with black nickel hardware, white/black/white body and headstock binding, white neck binding and a matching figured maple headcap.
Retail value - $799.99 USD
FEATURES
Body
Cutaway: Single
Top wood: Quilt maple arched top
Back & sides: Mahogany
Body finish: Satin
Orientation: Right handed
Neck
Neck shape: U
Nut width: 42mm (1.65")
Radius: 350mm (13.78)
Fretboard: Rosewood
Neck wood: Mahogany
Scale length: 24.75"
Number of frets: 22 XJ
Neck finish: Satin
Electronics
Active or Passive: Passive
Selector: Three-way toggle switch
Controls: Volume Neck, Volume Bridge, Master Tone, Push/pull pot on tone control splits coils on both pickups
Pickups: (Bridge): Black open-coil DiMarzio PAF 36th Anniversary, (Neck): Black open-coil DiMarzio PAF 36th Anniversary
Other
Tuning machines: Grover
Bridge: Tune-o-matic bridge and tailpiece
Saddle & nut: Molded
Number of strings: 6
Special features: Flag inlays
Case: Sold separately
We want to extend a BIG THANK YOU to Acme Branding Company for supporting the Slot Racers Giving Back charity fundraiser!!
:text-bravo:
Phone: 603.753.6263
SlotCarCorner
Postby Z-carfan » Fri Mar 17, 2017 8:45 pm
WOW!!!!
Mike
"When you’re back there with the squirrels, you’re bound to get your nuts cracked." - Graham Rahal
Postby SlotCarCorner » Sat Mar 18, 2017 6:29 pm
Our good friends at Clover Leaf Racing have donated a Clover Leaf Racing racing jacket. This is a great 3-season jacket featuring a distinctive Clover Leaf Racing logo - size 2X only.
Image Image
Phone: 603.753.6263
SlotCarCorner
Postby SlotCarCorner » Sat Mar 18, 2017 6:56 pm
Dave Wickham has donated a Limited Edition Slot.it Porsche 962 IMSA Budweiser #86. Part number SISC25A - a limited number of these were given as prizes at the 2014 Scalextric N. America TransAm Championship hosted by GT Slots.
Phone: 603.753.6263
SlotCarCorner
Postby HomeRacingWorld » Sun Mar 19, 2017 9:44 am
Posting by request. Here are the race poster signs and mugs.
"They didn't say you couldn't" - Smokey
Postby mikeinclover » Sun Mar 19, 2017 7:56 pm
Keep up the good work guy's we are now over $1000.00.
Mike
Clover Leaf Racing
7746 Clyde Road
Fenton MI 48430 U.S.A.
313-473-SLOT
web site: http://cloverleafracing.com
Facebook: http://www.facebook.com/cloverleafracing
YouTube Chanel: http://www.youtube.com/user/CLR132slots?feature=watch
mikeinclover
Postby Corvette man » Fri Mar 24, 2017 4:36 am
Can't wait for the race weekend . Good times.
Corvette man
Postby cgingras » Sun Mar 26, 2017 2:55 pm
CG SlotCars has also added some very nice prizes to the list of prizes.
To begin, there will be a $20 gift certificate to buy CG SlotCars products on Shapeways.
Then, a complete assortment of 14 and 15mm wheel inserts, knock-offs and guide adapters that CG SlotCars has released so far (that's a very nice assortment!!).
Finally, Matt has generously donated a yet-to-be-released Can-Am car to add to the raffle prize list. Wow!
Get your tickets now, time is running out!
cgingras
Postby busterfla » Sun Mar 26, 2017 9:47 pm
Donated another $50, like last year. I did well in prizes last year. Going to send a email to opt out of the Difalco controller (I have a 30 band already) and the guitar is useless for for a deaf guy :lol:
I like this great cause.
Buster
busterfla
Postby Changing-Gearz » Tue Mar 28, 2017 8:03 am
This is the prototype of the car we are donating. Winner will get the first production produced car.
CG's two charity's will once again be Lemons of Love - a very good group started by a friend of mine - they deliver goody-bags to people going through heavy duty chemo treatment.
http://lemonsoflove.org/home.html - and our other charity is the Fisher House who provide military families with housing assistance for injured/sick military personnel.
Good luck to everyone and thank you for supporting this great event!
*CG Slotcars*
....We do it in 3D....
Changing-Gearz
Postby Almafan 55 » Thu Mar 30, 2017 8:30 pm
Was informed today that Grizzly Racing is donating their portion to some Great Charities . 1) Shriners Children's Burn Charity! 2) HRW ! Yes our own Home Racing World! Now that some Great choices men!
There's less than 3 days left, we have some of the BEST sponsors donating some great prizes!!! Thank you All! With 1700 members donating just 1 dollar we could match last years $3400. So I ask PLEASE hit the donate button . :text-thankyouyellow:
Almafan 55
Users browsing this forum: Glenn and 5 guests
